Solar load in Icepak
Old   September 18, 2012, 10:56
Default Solar load in Icepak
drejac is on a distinguished road
Hi all,
I was simulating an enclosure in Icepak with solar load and noticed some unlogical behaviour. Then I tested a very simple model (a rectangular plate under the sun) and noticed the following:
- no matter what values for direct and diffuse solar absorption of the surface I set the result (temperature of plate) is always the same
- there is a temperature increase even in case when I set absorption to 0 and sunshine fraction to 0, since it seems that diffusive irradiation is always assumed to be absorbed completely (even if diffuse irradiation absorption is set to 0)
It is also not clear to me how the sun's position is calculated, since only the northward direction is required as input. It seems that gravity direction also plays some role as an error is reported if northward and gravity direction are the same. (I didn't try what happens if gravity is not defined)
Does somebody know how exactly the solar load model works in Icepak and do the above results imply a bug or am I missing something?
drejac is offline   Reply With Quote
solar load in fluent parallael processing guetat FLUENT 1 July 26, 2012 20:40
Solar Load Effects in Fluent Boreas FLUENT 1 December 15, 2010 01:15
solar radiation load rahulrahul155 Main CFD Forum 6 November 20, 2009 00:43
Tutorial: Using Solar Load Model for Indoor Ventilation amscosta FLUENT 0 July 17, 2009 18:09
Using the discrete ordinates solar load model Gary Slavin FLUENT 0 January 23, 2009 08:17
