Error writing compressed file during auto save
Like Tree13Likes
Old   September 12, 2016, 09:35
Default Found solution to error writing gzip
  #21
mohan jagadeesh kumar m
mohan_mandapati is on a distinguished road
hey guys.
here is the solution.
go to: http://www.gzip.org/gzip124xN.zip
download the file. copy and paste gzip.exe at
C:\Users\admin\AppData\Local\Temp
it's working. all the best.
mohan_mandapati is offline   Reply With Quote
Old   October 5, 2016, 07:48
Marnoq
Marnoq is on a distinguished road
Originally Posted by Drdalyo View Post
Hey guys,
So all of the above solutions did not work for me but I found a fix!!!
I think this could be an issue with people on windows 10 but not sure.
Basically i realized that my gzip.exe was also crashing when I recieved the error, so i went into the fluent folder and found the gzip.exe and did a simple test to see if it would work in cmd. Basically i tried to gzip a text file and found that it crashed!! Yureka! So this told me that the gzip.exe file itself was corrupt or not compatible with windows.
So I went to: http://www.gzip.org/gzip124xN.zip
Got the new gzip.exe and replaced this one with the one installed in my ansys folder at C:\Program Files\ANSYS Inc\v170\fluent\ntbin\win64 and overwrote the gzip.exe.
Now everything works!!!
If this helped you, please consider checking out and subscribing to my youtube channel at:
www.youtube.com/user/drdalyo
I have some video tutorials in CFD,
Regards
Thank you Drdalyo, this worked for me:
I have problem "loading" .gz files on Windows 8 and 10, also saving them in .gz format. I replaced both gzip.exe and gunzip.exe files with the new "gzip.exe you provided" and rename one of them back to gunzip.exe [in C:\Program Files\ANSYS Inc\v170\fluent\ntbin\win64]
This was a perfect solution!Thanks!
Marnoq is offline   Reply With Quote
Old   October 10, 2016, 13:46
MT
Xerrif is on a distinguished road
Originally Posted by Sneha William View Post
Power options setting in the PC should be changed to overcome this error. Set 'put computer to sleep' as 'never', and then in 'change advanced power settings', click on 'hard disk' and set 'turn off hard disk after' to 'never'. Also ensure that in the 'sleep' option, 'sleep after', 'allow hybrid sleep', and 'hibernate after' are set as 'never' ...
Great it helped
Xerrif is offline   Reply With Quote
Old   October 24, 2017, 03:09
Smile asking solution of gunzip.exe problems
  #24
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hi all,
I have other problems when I am reading my running file. gunzip.exe does not work. Can you give me the solution? I am using Ansys Fluent 17.2 in windows 10.
Thank you
Best Regards
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   November 5, 2017, 02:50
Question Error on reading gunzip file
  #25
teguhtf's Avatar
teguh hady
Dear all,
I am trying to open the file of my previous simulation. I am using FLUENT 17.2 in Windows 10. I have problem in opening due to gunzip.exe doesn't working while opening. Can you tell me the solution of problem?
here is the warning
> Reading ""| gunzip -c "C:\Users\root\CFD Teguh\ribbed-tube-2mm-60deg-amgsolver_files\dp0\FFF\Fluent\FFF.1-Setup-Output.cas.gz"""...
Building...
mesh
Error: Null Domain Pointer
Error: Null Domain Pointer\n
Error Object: #f
Thank you so much
Now Or Never!!!
Old   January 5, 2018, 10:34
Default on overwriting the gzip.exe
  #26
daniel_pramudita is on a distinguished road
Hi Drdalyo,
Did you mean overwrite the gzip.exe in the Ansys folder with the gzip.exe you downloaded from http://www.gzip.org/gzip124xN.zip?
Sorry, I got the opposite impression from your explanation and got confused.
Hey guys,
Regards
daniel_pramudita is offline   Reply With Quote
Old   August 9, 2018, 10:57
Default Error locating http://www.gzip.org/gzip124xN.zip
  #27
Arman
Arman Mansuri is on a distinguished road
There is an error when i click on the link http://www.gzip.org/gzip124xN.zip
It reads " Not Found
The requested URL /gzip124xN.zip was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request. "
Please help me in the direction.
Arman Mansuri is offline   Reply With Quote
Old   August 9, 2018, 15:49
Lucky
Just go to gzip.org which will link you to the gnuzip page
Old   April 18, 2020, 04:40
samarth GS is on a distinguished road
Should the entire .zip folder has to be or just the .exe files?
If so cant find any .exe files.
Please help
samarth GS is offline   Reply With Quote
Old   April 19, 2020, 03:13
Could anyone post a link for gzip.exe file, All the other folders are in .zip folder. Can't find .exe file.
Thank you
Old   April 20, 2020, 06:05
Default gzip
  #31
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Why do you need gzip? It is automatically installed with Fluent and is available at same location as fluent.exe in Windows. Linux has it preinstalled.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 20, 2020, 09:39
The preinstalled version is crashing. I need new gzip.exe and gunzip.exe.
Old   April 20, 2020, 09:58
Default Crashing
  #33
vinerm's Avatar
Vinerm
What do you mean by crashing? You cannot use these files by standard double clicking approach Windows follows. These can only be used via command or by Ansys tools that are linked to it. You can re-install Ansys to get it back.
Regards,
Vinerm
auto, compressed, error, file, save
[swak4Foam] problem on installing swak4Foam navid2 OpenFOAM Community Contributions 2 May 30, 2012 05:32
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
