Gridgen periodic boundary conditions in Fluent
Old   August 31, 2012, 09:26
Default Gridgen periodic boundary conditions in Fluent
chrischensong is on a distinguished road
Hi all,
I have generated a 3-D mesh with rotational periodic boundary conditions in Gridgen and imported it into Fluent. Everything is fine if I use serial in Fluent. But once I want to use parallel, the mesh cheking will fail. The message is like this: Warning: Number of nodes read does not match number referenced . Resetting counter to match the number referenced.
Does anyone has this problem before?
If anybody knows how to solve this problem, please let me know. Thanks in advance.
chrischensong is offline   Reply With Quote
Old   September 2, 2012, 00:22
Finally, I solve it. The mesh generated in Gridgen with periodic boundary conditions could not be recognized well in Fluent due to the poles were used in my case. It can be found by importing the mesh into Gambit.
One easy way to solve it is to use TUI in Fluent 6.3, Grid>modify-zones>repair-periodic. There will be no problem in Fluent parallel solver anymore.
Anyway, I believe it may be a compatibility problem of different software since Gridgen is not designed only for Fluent. Welcome to discuss.
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 03:18
[ICEM] Boundary conditions problem in ICEM and Fluent Far ANSYS Meshing & Geometry 6 September 10, 2014 20:48
periodic boundary conditions in multiphase model swarnajay FLUENT 1 July 24, 2009 12:04
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
