August 31, 2012, 00:51 |
Velocity of flow v time
Ant Burrows
I'm hoping you can help me out here. It'll probably turn out to be quite a simple thing to do, but I can't fathom out how to do it. I have a modelled and meshed a flow meter that features vortex shedding using Ansys Workbench 12.1 or 14, depending which computer I use. It's in 2D and I'm using the k-epsilon model. Firstly, as the flow is constantly switching from side to side of the bluff body in the middle of the flow meter, as it should, I assume that it is unlikely to converge or take a long time to converge unless I change the convergence criteria from the defaults (I've run simulations with a modest mesh for hours without convergence). Is this correct/likely? Secondly, to determine the flow rate through the meter, I wish to determine the frequency of the flow as it switches from side to side of the bluff body as this is proportional to the flow rate. I've set a surface monitor close to the bluff body to measure the velocity of the flow and when the simulation is run a plot shows the velocity to increase and decrease. However, this is velocity v iteration. I'd like velocity v time. How can I do this? Finally, I'd like to create a set of contour plots at set intervals of time to show a complete cycle of the oscillation of the flow either side of the bluff body. This is related to the second point in that I am not aware of how to determine time as opposed to iteration. Is there a tool or way of doing this? Any help on any of these points is greatly appreciated. Thanks, Ant Ps if you need more info, let me know. |
ansys 12.1, convergence, time dependence plot, velocity, vortex shedding |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 05:35 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 03:13 |
