Negative volume in internal combustion engine analysis
Old   August 16, 2012, 17:40
Default Negative volume in internal combustion engine analysis
Ahmet
a_cucen is on a distinguished road
I m trying to make an internal combustion engine analysis in fluent. I have set dynamic mesh zones.when displaying zone motion, it looks like ok. But when I Preview mesh motion, It gives this error and makes negative volume. What can I do to fix this problem? I realized that it is about cylinder motion. But I could not find the solution.
"Warning: Mesh projection of deforming dynamic zones exceeds reasonable limits.
Please verify that the correct geometry definitions have been specified. "
a_cucen is offline   Reply With Quote
Old   August 18, 2012, 09:38
Ahmet
I have found that my deforming and stationary surfaces are not matching. Can I measure an edge lenght or diameter in fluent?
Old   April 12, 2015, 16:40
shadiparsa is on a distinguished road
hello!
I am having the same problem right now also!
did u find any solution for that?
shadiparsa is offline   Reply With Quote
Meshing Structure for Internal Combustion Engine Majid FLUENT 1 January 1, 2010 16:56
negative volume encountered Maga CFX 2 October 7, 2009 18:31
CFD simulation in Internal Combustion Engine Anne Main CFD Forum 17 May 5, 2005 06:06
internal combustion engine port flow simulation Nyquist Siemens 1 April 29, 2003 04:48
