July 30, 2012, 17:34 |
Open Channel Boundary Conditions Issues
Rep Power: 14 |
I have modeled an open channel using FLUENT 6.3 (3D). I have encounter many issues in the boundary conditions defining.
I specified the inlet by "Pressure Inlet" BC. As I used the "Open Channel" option on the "multi-phase" tab of the Pressure Inlet BC panel, I entered the following parameter to define the BC: Free Surface Level, Bottom Level, and Velocity magnitude as well as k and epsilon. My problem is that after solving the field, the inlet velocity differs significantly from the value I have entered in the Pressure Inlet BC condition. I have searched all the FLUENT documentation to find equations of open channel BCs, but nothing specific for open channel are there. Does anyone know how the FLUENT have used the velocity magnitude I have entered? and why the velocity magnitude in the inflow face after calculation is not the same as the velocity magnitude I have entered? I have checked the "Mass Flow Inlet" BC for open channel which requires the same parameters as the "Pressure Inlet" without velocity magnitude! That means "Mass Flow Inlet" may define the BC using only Free Surface Level and Bottom Level. How is it possible? Is the "Pressure Inlet" BC over defined? I appreciate if any one help me understand how do boundary conditions for open channel work. Other information about the model: Multi-phase Model: Implicit VOF Turbulence Model: k-e (RNG) Outlet BC: Pressure outlet Top BC: Symmetry Many thanks in advance, Env |
August 31, 2012, 14:19 |
#2 | |
Rep Power: 14 |
I am facing similar problem. The velocity magnitude specified in the pressure inlet boundary condition does not matches with the simulation result. I have tried using the velocity inlet boundary condition. But the solution does not converge. Please let me know if you have found details about the open channel boundary conditions in VOF. Quote:
September 1, 2012, 23:02 |
Rep Power: 14 |
Hi rasha,
Thank you for your reply. I have asked sense guys in my university to post my question on Ansys Support portal. However, if you can do that please post on the link below. https://www1.ansys.com/customer/default.asp If I found any solution, I'll let you know. If you found anything, please let me know, too. Thanks, Env |
October 21, 2012, 14:36 |
Siamak Gharahjeh
Rep Power: 14 |
I've tested a way which I think works. let's first remember that if flow is driven due to gravity, then the velocity at the pressure inlet must be unique. That one velocity magnitude is nothing but the true magnitude which may be measured in the lab. So, what you do is you put the actual velocity there, otherwise you should approach that velocity in an iterative manner without the lab measurement. you can start with zero magnitude for velocity in the inlet and solve(now V is not zero anymore), next, calculate the velocity by dividing the flow flux(flux in the pressure inlet) by flow area again at the entrance. Now you have a velocity, go back to BC and put it there and iterate and so on. But usually doing so for one time works good.
June 27, 2016, 12:19 |
Magnitude difference in velocity in BC and simulated data
Tanjina Afrin
Rep Power: 13 |
Hello Env and Rsaha,
I am facing the same problem. The provided velocity at BC is not matching with simulated velocity. Did you get any solution for that problem? Regards, Tanjina |
June 27, 2016, 19:41 |
#6 | |
Rep Power: 14 |
For my case I ignored the changes of velocity at the BC, since the interest region was far from the BC. I hope it helps you. |
June 27, 2016, 22:15 |
Tanjina Afrin
Rep Power: 13 |
Thanks Env.
For my case, I am defining free surface level ( I guess which means constant water level), so there is no chance to change the pressure. Then why I am getting different velocity? it changes from 1.54m/s to 0.0003 m/s ! |
June 28, 2016, 13:14 |
#8 | |
Rep Power: 14 |
However, you have significant changes in flow velocity. It means something else is wrong. It could be mesh issue, solution controls and equations, or may be your specified values of velocity and water surface is not consistent with your domain. Check your outlet BC, gravity direction etc. |
June 28, 2016, 16:05 |
#9 |
Tanjina Afrin
Rep Power: 13 |
Thanks Env. I will look into this by changing these variables.
boundaries condition, fluent, multi phase, open channel, vof model |
Open Channel Flow - Setting Boundary Conditions | Christine Sindelar | FLUENT | 6 | June 6, 2011 04:11 |
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 07:32 |
LES of channel with cylic boundary mapping boundary conditions | Thomas Baumann | Siemens | 0 | August 24, 2009 09:53 |
Problem with VOF open channel modelling | Biswanath Mahato | FLUENT | 1 | September 14, 2006 04:20 |
open channel flow boundary conditions | yan | FLUENT | 0 | July 4, 2005 23:36 |
