Simple drag coefficient question
Old   July 28, 2012, 02:05
Default Simple drag coefficient question
Holly
Hnthompson is on a distinguished road
After you get the solution from fluent and go results > reports > forces and then plug in the x- and y-velocity components under set up, which number that the software spits out is the drag coeffecient?
Hnthompson is offline   Reply With Quote
Old   July 29, 2012, 08:39
cfd seeker is on a distinguished road
you don't have to put the values of velocity components instead put the values of cos and sine components of the angle at which you are performing your analysis. The last most number on the right side is the coefficient of drag.
Regards
cfd seeker is offline   Reply With Quote
drag coefficient
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 01:49
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
coefficient drag JEHERZ CFX 5 February 9, 2012 07:28
Drag coefficient & Lift coefficient?? mehrdadeng CFX 15 December 9, 2009 22:49
drag coefficient with k-eps model Mark Main CFD Forum 8 April 19, 2004 10:55
