solver setting
Old   July 26, 2012, 18:04
Default solver setting
nabizadeh
eb.nabizadeh is on a distinguished road
can any one help me please?
i have a 3D model(a house)that i want to check temp & flow in it.my model is transient & the volume of it is 400m3,walls are at initial temp 20 c and when wind blowing into it exchange it's heat with walls.but i have some problem in convergence.i want some one to say exact setting about my model.what under-relaxation factor is good for it,which viscose model is better.finally what must i do to converge my problem.thanks
eb.nabizadeh is offline   Reply With Quote
Old   July 26, 2012, 18:15
nabizadeh
i don't have much time please help me early
Old   July 27, 2012, 03:12
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hello
If I were you I would try first with a k-epsilon model (Realizable o RNG).
Maybe it's better to reduce the URF (M=0.2 E=0.9 should be enough).
First order upwind for discretization and PRESTO! for pressure scheme.
Bionico is offline   Reply With Quote
Old   July 27, 2012, 04:55
Sixkillers is on a distinguished road
Also It depends which model you use for air density. Are using ideal gas model or Boussinesq approximation? Generally speaking ideal gas model is harder to converge.
Sixkillers is offline   Reply With Quote
Old   July 27, 2012, 10:50
nabizadeh
i use Boussinesq model for density.i want to know what criterion(surface integrals) can i consider except residual?
Old   July 28, 2012, 05:16
nabizadeh
dear Bionico
when in do what you said i facing this error:floating point exception!
and when i change my turbulence model it didn't converge.
can you help me more?
Old   July 30, 2012, 03:42
Bionico's Avatar
Flavio
ok, it's a convergence problem...
since this is a transient simulation, try reducing the Courant number under 1
Old   July 30, 2012, 18:45
Smile
nabizadeh
you mean i use density based or pressure based?
Old   July 31, 2012, 03:01
Bionico's Avatar
Flavio
No, but maybe (I don't remember very well) the Courant number can be controlled only in COUPLED problem (not if you have a SIMPLE one).
Therefore try reducing time step and increasing number of iteration/time step
[Other] A New Solver for Supersonic Combustion nakul OpenFOAM Community Contributions 20 February 22, 2019 10:08
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
