Combustion Modeling in internal combustion engine
Old   July 26, 2012, 16:36
Question Combustion Modeling in internal combustion engine
CO
Joeyt is on a distinguished road
Hello!
I am trying to run a 3D in-cylinder spark ignited combustion model of of an engine. I can run the model perfectly through a cycle with cold air, but when I introduce combustion with a premixed fuel model the solution diverges just a few time steps after spark ignition. I tried playing around with the underrelaxation factors, but it is still diverging at the same point. are there any tricks to addressing this type of situation that someone has dealt with before?
Thanks!
Joeyt is offline   Reply With Quote
Old   May 23, 2013, 08:57
Amit
amitbdt143 is on a distinguished road
Hi Joeyt,
Did U Solve your combustion problem successfully. Now I'm facing the problem as you mentioned above.
Regards
Amit
amitbdt143 is offline   Reply With Quote
Old   May 25, 2013, 15:20
Zacarias Carral
zcarral is on a distinguished road
Try to refine the mesh, reduce the time step and incement the relaxation factors.
zcarral is offline   Reply With Quote
Old   May 26, 2013, 06:30
Amit
Thanks for your suggestion. I'll try it out.
Regards
Amit Kumar
combustion engine, combustion instability, diverging solution, in-cylinder, spark model
Modeling Hyrogen Sealing in an internal combustion Engine anatoliafire Main CFD Forum 0 May 3, 2010 03:40
Intrenal combustion engine (CI) modeling Majid FLUENT 0 August 2, 2009 10:04
Internal combustion engine Akuma FLUENT 0 January 30, 2007 07:02
Internal combustion engine Akuma FLUENT 0 January 30, 2007 03:58
combustion in internal combustion engine George Main CFD Forum 0 September 7, 2006 15:41
