High Y plus wall values despite sizing, inflation and refinement |
July 23, 2012, 12:48 |
nauman hashmi
Rep Power: 14 |
i am getting high wall y plus values despite sizing, inflation and refinement. i am gtg value in exp of 5 or 4 desired values are for SA model. help required.
regards |
July 23, 2012, 14:50 |
Alex
Rep Power: 49 |
Could you rephrase the question? I didn't get it.
July 23, 2012, 14:53 |
elaboration of the query
nauman hashmi
Rep Power: 14 |
sir i am interested to model flow around an aircraft at mach 0.8. i am using SA model and facing problem of high y plus value they are in range of 3 exp 5. i have refined my mesh and changed settings for my inflation layers. however yet the values are not coming down. need guidance on this issue.
regards |
July 24, 2012, 03:07 |
Philipp
Rep Power: 27 |
What's the thickness of the first cell at the wing? What's the size of the aircraft?
July 24, 2012, 03:19 |
Alex
Rep Power: 49 |
Did I get you correctly? Althoug you change the thickness of the first cell, the Yplus values do not change?
I can't recall such a bug in Fluent. |
July 24, 2012, 06:27 |
calrifications
nauman hashmi
Rep Power: 14 |
the size of aircraft is around 18 m long and the thickness of first layer is 1 exp -7. still the Y plus is very high. may be i am doing some things wrong. the mesh quality as per skewness and orthogonal quality is good.
regards |
July 24, 2012, 06:30 |
Philipp
Rep Power: 27 |
So your first layer thickness is 100nm? Did your solution converge? What's the largest residual?
July 30, 2012, 15:09 |
Convergence values
nauman hashmi
Rep Power: 14 |
sir the convergence values are 1 exp -3. i have also used mesh adaptation but no avail. i seek guidance on this regard.
thanx |
July 31, 2012, 15:20 |
#9 |
Rep Power: 20 |
July 31, 2012, 15:44 |
RE: CFD seeker sir
#10 |
nauman hashmi
Rep Power: 14 |
sir mesh is scaled in the same units. i have tried both hexa and tetra meshes to get desired values but no avail.
regards |
August 1, 2012, 04:06 |
#11 |
Rep Power: 20 |
could you please share your geometry and mesh file with me along with flow and boundary conditions if its not confidential, I will try on it and will let you know.... are you making your mesh in ICEM or Gambit or anyother software?
August 1, 2012, 04:47 |
geometry sharing
#12 |
nauman hashmi
Rep Power: 14 |
sure sir if i may have ur email address. my email is naumaneshanhashmi@gmail.com if you can send me a blank email, i will send you the requisite files.
regards |
August 1, 2012, 11:54 |
#13 | |
Rep Power: 20 |
August 1, 2012, 16:14 |
#14 |
Rep Power: 20 |
kindly mail me the parasolid or acis(sat) version of your geometry as I use ICEM for meshing. Thanks
Regards |
