FLUENT Periodic Boundary Condition SOLVED + TUTORIAL |
December 2, 2016, 10:30 |
#41 |
Rep Power: 10 |
Didn't help....
Some pictures would be fine. Some steps are hidden. |
December 2, 2016, 16:00 |
#42 |
Rep Power: 18 |
March 15, 2017, 16:24 |
#43 |
amir ghasemi
Rep Power: 11 |
there is no problem with specifying more than one periodic boundary condition. but i'm confused in this: when i specify the flow direction for one set of periodic boundaries , the flow direction for other boundary changed automatically, which is not desired. do u have any suggestion for me??
thanks |
March 15, 2017, 16:26 |
#44 |
amir ghasemi
Rep Power: 11 |
thanks |
March 15, 2017, 18:05 |
#45 |
amir ghasemi
Rep Power: 11 |
Hi i wish u could help me,
there is no problem with specifying more than one periodic boundary condition. but i'm confused in this: when i specify the flow direction for one set of periodic boundaries , the flow direction for other boundary changed automatically, which is not desired. do u have any suggestion for me?? thanks |
March 17, 2017, 14:11 |
#46 |
Constantinos
Rep Power: 10 |
Hi guys, Im having some trouble making the rotational periodic boundary conditions. So im trying to model a blade rotating while the rest of the domains are stationary. Ive tried using the method described at the beginning of this thread but my mesh wont work after i apply the changes. So i have three domains: the big one along with the medium one are both stationary while the smaller one will be rotating, but i have to apply the rotational periodic boundary condition on all three of them i guess. My middle domain is so that i can have a finer mesh around the blade. Could anyone help me?
March 17, 2017, 23:51 |
#47 | |
amir ghasemi
Rep Power: 11 |
If u are using ansys meshing try ""mesh match"" for specifying periodic boundaries and then u could have a better control on the other boundaries.like aplying "refinment" . Hope can help u |
March 18, 2017, 05:25 |
#48 | |
Constantinos
Rep Power: 10 |
Sent from my A0001 using CFD Online Forum mobile app |
March 18, 2017, 06:20 |
#49 | |
amir ghasemi
Rep Power: 11 |
Mesh matching will chang some of your previous settings, automatically. Perhaps its better to try different methods |
March 19, 2017, 06:59 |
#50 |
Constantinos
Rep Power: 10 |
Hi again, it was suggested that i would apply periodic b.c separately for each of the domains, however that didnt work. Is there something im missing? Do you need any special conditions to be able to apply periodic b.c?
March 21, 2017, 15:27 |
#51 |
Constantinos
Rep Power: 10 |
So i figured that the mesh on the periodic boundaries should match and so i applied match control. I have applied them on two of my faces but it does not work on the faces that are going to be rotating and i get an error that they dont have the same geometry or topology although all 3 domains have the same boundaries. Could anyone help me?
April 8, 2017, 14:52 |
#52 |
Rep Power: 10 |
May 10, 2017, 15:44 |
#53 | |
In Mesher, goto models>symmtery>and right click on it to apply symmetry Region from (symmetry Region, periodic or cycllic) Then in the symmetry first menu under definition, set Type to Linear periodic, MEsher will automatically ask in the top of the menu to selct higher and lower surface. Then you will get this region as linear periodic and Fluent will apply translational boundary. |
November 5, 2017, 02:38 |
Asking periodic boundary condition
#54 |
teguh hady
Rep Power: 18 |
Dear All,
I have the same case. I am trying to solve simulation of plain pipe by using periodic boundary condition with Internal Diameter 15.88 mm, Length 22.5 mm. The inlet temperature of water flow is 27 C and the mass flow is 0.0166 kg/s. The wall is constant temperature at 17 C. However, when I try to simulate the there are several errors. How to solve these errors? Thank you so much %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% Error: Non-conformal periodic interface with empty intersection. This is likely due to incorrect specification of periodic offset values. Please check the offset values specified and recreate the interface. Error: Couldn't intersect threads 5 and 6. Error: Couldn't intersect threads 5 and 6.\n Error Object: #f
Now Or Never!!! |
November 18, 2019, 17:14 |
#55 |
Alexander Li
Do I understant it correctly, to relized periodic b.c, rebuilding two faces in Fluent using TUI is the only approach?
July 11, 2020, 07:40 |
#56 |
Hassan
Rep Power: 6 |
Hello
I am doing transient simulation for the fluidized bed with 3D geometry... the problem is that solution is converged for some second's simulation and after that it does not converge .... what should be the possible solutions???? i have change controls and convergence criteria and methods but issue is still there |
fluent 13.0, how to, periodic boundary, tutorial |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Symmetry and Periodic boundary conditions | CFD_Fluent_User | FLUENT | 1 | October 16, 2014 03:18 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 07:49 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 12:32 |
Periodic boundary condition & Unsteady flow | Somchai | FLUENT | 2 | March 28, 2006 09:51 |
