Optimization
Old   July 19, 2012, 00:43
Default Optimization
Osama
osamaghani is on a distinguished road
Hello everyone!
I want to do aerodynamic shape optimization using fluent, design modeller,ICEM and matlab and an optimization code( I do not know what I will use..)
Basically my aim is to;
1. create/modify a part of geometry in Matlab..
2. attach geometry to the rest of the body in CAD software..I can use solidworks ...or design modeller(i think design modeller would be efficient)
3. generate mesh in ICEM
4. simulation in FLUENT
5. send to optimizer and go to 1...and repeat until optimized solution is obtained.
I have been using these software but do not know how to communicate..I can work with replay scripts in ICEM..
I would appreciate if anyone can help me in this regards
thanks!
osamaghani is offline   Reply With Quote
Old   July 19, 2012, 05:48
Marion
Marion is on a distinguished road
If you want to use Fluent I think the simpler way is to use it within workbench (not sure it is the cheapest!).
Within workbench, you have design modeller + ansys meshing for the mesh, then Fluent and then the optimisation package is design explorer.
With the workbench project workflow it's pretty convenient as it does everything itself (be careful with the set up though - it cannot think for you ;-)), using different types of optimisation.
We have all these packages available where I work, but I don't know about other optimisation softwares.
Marion.
Marion is offline   Reply With Quote
Old   July 19, 2012, 12:59
Osama
Hi Marion,
thanks for the reply.
Your suggestion makes sense to me but I am doing MASc research and I need more flexibility for geometry. I need to make some parts on my geometry in matlab by curves and surfaces. I can not use the dedicated CAD software for my complete geometry if you have any material available for design explorer..I would appreciate if you could share!
Old   February 26, 2013, 10:36
Stefano
stefmascio is on a distinguished road
I suggest you to try with IOSO Optimization software.
It works very well with Matlab or Fluent and it has really good optimization algorithms!
stefmascio is offline   Reply With Quote
shape optimization
COMSOL: optimization applied to a laminar flow tdh89 COMSOL 0 April 30, 2012 09:57
How to do Design Optimization in Fluent 13.0? p36288 Fluent UDF and Scheme Programming 1 July 20, 2011 01:37
Polyhedral Optimization Mlynam Siemens 2 August 6, 2010 12:26
BOOK ON OPTIMIZATION OF FORTRAN CODES Alberto Main CFD Forum 3 November 10, 2008 07:07
