Initial Solution Fluent
Old   June 22, 2012, 16:26
Default Initial Solution Fluent
Fer Villa
fevi84 is on a distinguished road
Is possible initialize a Fluent case with a preliminary solution, ie,having the velocity field and pressure field in the calculation domain obtained from previous solution. I want use the solution obtained from the aplication of VOF method for run the same case with of Eulerian method.
I already did the following: ran x iterations using the VOF model, and then, I configured the Eulerian model. But I want run directly the Eulerian model using as initial solution the velocity field and pressure field obtained with VOF.
If anyone know if this possible, please explain me how do it.
Thank you.
fevi84 is offline   Reply With Quote
Old   June 25, 2012, 06:27
Zigainer is on a distinguished road
I think you could to this with "interpolate"
file/interpolate/write-data .....
and
file/interpolate/read-data .....
Zigainer is offline   Reply With Quote
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 03:09
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
Error log vw.cfd OpenFOAM 6 August 7, 2009 06:44
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
