Vortex shedding in sphere
Old   July 5, 2016, 03:58
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Time step size = 0.02s
Max Itr per Time step = 30
What is vortex shedding period?
No benefit of increasing max itr per time step. Should not be more than 20. If you feel convergence problem then reduce time step by 50% which will have similar effect but with better convergence and flow features
Far is offline   Reply With Quote
Old   July 5, 2016, 07:13
Pranjal Seth
scyllakeeper is on a distinguished road
That is what I am trying to get.
I'm trying to simulate Vortex Shedding, for flow around sphere at Re 300.
scyllakeeper is offline   Reply With Quote
Old   July 5, 2016, 07:59
Far
Sijal
vortex shedding periodic = 1/frequency. Frequency is calculated from strouhal number
Old   July 5, 2016, 13:21
Pranjal Seth
Pardon me for misunderstanding. I do have that in my calculations.
Strouhal Number for flow past Sphere for Re 300 would be around 0.15. (rectify me if I'm wrong with this, source: http://citeseerx.ist.psu.edu/viewdoc...=rep1&type=pdf)
My U=300e-3m/s, and D=1e-3m
Sr = 0.15, so f = 45Hz
T = 1/f, = 0.0222s
So my cycle time is 0.022s
If I plan on having 20 to 25 time steps in one shedding cycle,
time step size = 0.022/22, = 0.001s.
Now I would use max iterations per time steps as 25.
Please do tell if any changes can be incorporated.
Old   July 5, 2016, 13:23
Far
Sijal
thats correct.
Old   July 5, 2016, 13:39
Far
Sijal
why are taking too low dia and velocity?
For Re = 300, why not put vel = 1 m, Dia = 1 m, density = 1000, so viscosity = 1000*1*1/300 = 3.3333
Time period = 1 / f ,
since strouhal no = 0.15 = f D / V
so frequency = 0.15 * V / D = 0.15 * 1 / 1 = 0.15
Therefore time period = 1/0.15 = 6.6667 s
For two steps , delta t = 6.6667 / 20 = 0.33335 s
Old   July 5, 2016, 13:56
Pranjal Seth
My analysis is for a Newtonian Fluid with density=1000kg/m3 and viscosity 0.001kg/s, so I'll have to stick to these values.
Anyway, keeping the simulation running.
Let's see how it goes. Would post the progress.
Thank you so much for this help.
Old   July 5, 2016, 13:57
Pranjal Seth
Do tell me if you have any additional suggestions/advice I could use.
Old   July 5, 2016, 14:01
Far
Sijal
why to stick to these values of density and viscosity? Reynolds number should be matched thats what we know from very basics.
Old   July 5, 2016, 14:45
Pranjal Seth
This is a project I am working on, where I need to study critical Reynolds number (the Re at which vortex shedding starts) for 6 given non-Newtonian power law fluids (for which consistency index and power index are given).
Results are to be analysed and compared.
In case of first test fluid, k = 0.001 and n = 1, which basically makes it a Newtonian fluid.
So I cannot really vary the fluid properties.
Old   July 5, 2016, 18:52
Far
Sijal
Is it hexa mesh?
Old   July 6, 2016, 03:38
Pranjal Seth
Yes.
Working on a fine mesh, as fine as it could've been with hexa cells.
Old   January 19, 2017, 13:18
Shashank
shashanktiwari619 is on a distinguished road
Did you get the results for drag and lift??Also do you get a proper vortex street?
I am doing a simulation for similar case. When I do simulations for a 2D cylinder with a very fine mesh for Re=100, I get a proper vortex shedding, however I don't get proper values of drag coefficient, lift coefficient and Strouhal number. In case of 3d flow past sphere for Re=300, I simply get a wake without any shedding?? I use the laminar-viscous model.
Please reply if you had any success with the simulations.
shashanktiwari619 is offline   Reply With Quote
sphere, vortex shedding
K-Epsilon for Vortex Shedding Sham FLUENT 33 March 29, 2017 06:48
What is the best "way" to get vortex shedding ? harly OpenFOAM Running, Solving & CFD 40 December 16, 2016 01:10
Transiet Animation - vortex shedding derz CFX 5 May 10, 2010 10:21
Vortex shedding behind cylider in cross flow Muthu FLUENT 0 March 6, 2006 11:29
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
