help in pressure drop calculation in fluent
Old   June 17, 2012, 08:32
Default help in pressure drop calculation in fluent
sina
sinaupdate is on a distinguished road
hi everyone
i want to calculate the pressure drop of fluid along a pipe with anuular section ,in result i see that the pressure drop that fluent give me is 200 pa less than exact pressure drop that it must be..
what is the reason for that??
lenght = 12 ft D_out = 2.91 in D_in=1.8 in mesh 2,600,000
out let boundary = 0 pressure
inlet boundary= velocity inlet
fluid =water
for water inlet with velocity INLET 1.58 i receive 1100 pa/m pressure drop but it must be more.
tnx for any help
sinaupdate is offline   Reply With Quote
Old   June 17, 2012, 09:39
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Have you set roughness in wall boundaries?
ghost82 is offline   Reply With Quote
Old   June 17, 2012, 17:52
sina
hi
yes roughness constant as a default is 0.5
i dont know when i do it by one liquid, result is little lower and when i use liquid-solid, pressure drop it twice the exact result !!
Old   July 10, 2016, 06:56
Omid Shekari
Omish is on a distinguished road
Originally Posted by sinaupdate View Post
hi
Hi
Did find the solutin about this problem? I have the same problem. Please let me know if you have solved it.
Omish is offline   Reply With Quote
Pressure drop calculation and comparison to analytic solutions n0name STAR-CCM+ 2 August 16, 2012 04:36
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
pressure drop calculation multi-inlet-outlet syst. timmyy FLUENT 1 April 24, 2007 07:03
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 13:30
pressure drop Jerry Hug Main CFD Forum 0 December 3, 2003 09:11
