Rep Power: 17 ![]() |
Hello All,
if someone runs into this issue: If you have bought the license for legacy Gambit, you need to install Exceed to work under Windows. After installing Exceed, you might get an error message "Missing us.kbf", which will prevent you from running Exceed. Solution: Reinstall Exceed. When running the EXE install file for Exceed, choose "Run as Administrator", and the error will be gone. Cheers |
errors when installing openfoam2.1 on ubuntu12.o4 | hewei | OpenFOAM Installation | 5 | May 29, 2012 07:43 |
OpenFOAM Installation | rclprice | OpenFOAM Installation | 1 | July 21, 2011 16:31 |
OpenFOAM installation problem. File missing in wmake | shangzung | OpenFOAM Installation | 1 | July 8, 2010 10:57 |
missing lnInclude files on gentoo ebuild installation | BlGene | OpenFOAM Installation | 1 | June 22, 2009 03:59 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
