Simulation of cylinder aligned in the flow direction using k-e model
Old   June 12, 2012, 14:06
Default Simulation of cylinder aligned in the flow direction using k-e model
Eli_Ja
Eliasjal is on a distinguished road
Hello everyone,
First of all , i' still a beginner to fluent and what I'm trying to simulate is the boundary layer flow over a cylinder aligned in the flow direction. Please see the attached picture that shows the boundary conditions. I used a periodic boundary between the inlet and the outlet of the domain whereas the mass flow rate was taken. Then I assumed the wall has no slip and outflow pressure for the outer domain.
I need some help from you guys to resolve the following questions:
1- Is the BCs that i used are corrects ?? I wonder whether or not do i have to use the field pressure instead of outflow pressure condition ??
2- How to define the number of layers that will be used for a wall zone. I need to plot Y+ vs u+ so I need to define the wall sublayer that will be used for y+ analyses ??
3- Do you guys have and reference link, paper or materials that shows a similar simulation that i can use for comparing my results ?
4- In case of a spinning wall, do i need to use a dynamic mesh or just using the cell zone conditions ?? and if so then what is the proper choice, the frame motion or the mesh motion ???
thank you very much for your help
Regards,
EJ
Eliasjal is offline   Reply With Quote
Old   June 13, 2012, 05:27
delaneyluke is on a distinguished road
First of your external domain has to be way bigger if you want to capture the flow over your cylinder. Browse the net for external domain sizes for your type of problem.
To answer your qns
1. Use a velocity inlet and pressure outlet. For outer walls use the far field pressure BC
2. Use any Y+ calculator available to find out first layer height
3. Not at the moment
4. In case of a spinning wall, you can give the angular velocity to the wall, you don't need to do a dynamic mesh analysis
P.S You could work with a sector instead of the entire cylinder
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   June 13, 2012, 09:00
Eli_Ja
Hey Luke,
First of all thank you much for your response.
If there is any specific relation that define how much the size of the domain must be ?? or how large the external domain (i.e the outer cylinder diameter ) should be for my case ??
Actually I tried to avoid using a rectangular box just to eliminate some edge effect at the corners of the domain which happens in the rectangular box domain.
Just one more thing about your answer for q.1:
actually, I'm not simulating the entire model of the cylinder but just a sector of it and that is why I used a periodic boundary conditions.
looking forward to hearing from you.
Thanks
EJ
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
Flow over a cylinder Ari Guerrero CFX 6 September 30, 2005 04:47
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
Simulation of the Flow past a circular cylinder using STAR-CD M. S. GUEROUACHE Main CFD Forum 0 October 1, 1998 11:51
