June 12, 2012, 02:24 |
Y plus values
Osama
Rep Power: 14 |
I am modelling 2d flow over a bluff body..
Domain consists of Inlet, outlet, geometry(bluff body;wall), ground(wall) and far0field(wall) 1. I am using standard wall treatment and so the range of Y+ values should be in the range of 30 to 300..My question is should this condition be met on all the walls (ground...far-field..) of the domain or just the geometry(the bluff body) of interest... ? 2. To what extent can the Y+ lie out side this range..? I think its not very easy to get all the Y+ values in this range... for example for 1 simulation Y+ values on bluff bogy are in the range of 4.5 - 600 and the average is 100....do I need to redo the grid? I would really appreciate of you could also provide some reference |
June 12, 2012, 04:53 |
Osama
Rep Power: 14 |
can you please elaborate....does fluent have that?...btw do these values seem good to you or??
wall plus, y plus |
Mapping values from 2D mesh to 3D mesh boundary during runtime | benk | OpenFOAM Programming & Development | 1 | June 13, 2014 02:39 |
Numerical errors in nested domain with pre-calculated boundary values | Arnoldinho | OpenFOAM Running, Solving & CFD | 3 | April 4, 2012 10:31 |
max node values exceed max element values in contour plot | jason_t | FLUENT | 0 | August 19, 2009 11:32 |
exact face values | RubenG | Main CFD Forum | 0 | June 22, 2009 11:09 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
