Population Balance Modeling (PBM) - Ansys Fluent |
April 23, 2018, 09:13 |
how to plot size distribution curve and breakage rate (1/s) using PBE in fluent ansys
#121 |
apis yong
Rep Power: 8 |
hello need help urgent
how to plot size distribution curve and breakage rate (1/s) using PBE in fluent ansys? |
April 23, 2018, 09:14 |
#122 |
apis yong
Rep Power: 8 |
hello need help..how to plot size distribution curve and breakage rate (1/s) using PBE in fluent ansys?
April 23, 2018, 09:15 |
#123 |
apis yong
Rep Power: 8 |
April 23, 2018, 09:40 |
#124 | |
Masoud Ravan
Rep Power: 10 |
April 23, 2018, 10:02 |
#125 |
apis yong
Rep Power: 8 |
hi masoud, thanks for replying
there's something that i am still confused of.. eventhough just by turning on the phenomena like aggregation and breakage rate in fluent PBE did not automatically solve it or still need UDF? my plan is i want to plot a graph for droplet size distribution and breakage rate vs diameter. I really need help. |
April 23, 2018, 10:28 |
#126 | |
Masoud Ravan
Rep Power: 10 |
In order to plot size distribution, follow these steps: postprocessing-model specific-population balance-number density... Report type(volume or surface average) plot type(curve) Fields(Discrete number denstity) |
April 23, 2018, 10:43 |
#127 | |
apis yong
Rep Power: 8 |
this part i found it already. i am using pbe qmom. but regarding the upper diameter limit. how do you choose the best one? the default is 1.5. and for breakage rate can u tell me where can i plot it in fluent ? |
April 23, 2018, 11:12 |
#128 | |
nilesh
Rep Power: 9 |
April 23, 2018, 14:07 |
#129 |
apis yong
Rep Power: 8 |
April 23, 2018, 23:11 |
#130 |
apis yong
Rep Power: 8 |
April 23, 2018, 23:17 |
#131 | |
apis yong
Rep Power: 8 |
for this one the length number density has high values. the x-axis i put in log scale. for the length number density if i want to convert it to volume as part of droplet size distribution curve do i need to convert again or what? sorry i am still poor in this area. by the way i choose pbe-qmom then the size interval i set between 0.1 to 1e-07, at secondary phase i set sautermean diaemeter looking forward from your reply soon. |
April 24, 2018, 04:35 |
#132 | |
nilesh
Rep Power: 9 |
I am also trying the same. HAve you got the solution for your UDF in getting number density. Kindly reply. |
April 25, 2018, 05:15 |
#133 |
nilesh
Rep Power: 9 |
Did you get the solution for defining ni and nj?
April 25, 2018, 12:57 |
how to plot breakage rate in ansys fluent using PBE-qmom
#134 |
apis yong
Rep Power: 8 |
hello can somebody please guide me how to plot the breakage rates in fluent?
April 25, 2018, 13:03 |
#135 |
nilesh
Rep Power: 9 |
April 26, 2018, 17:47 |
#136 |
Masoud Ravan
Rep Power: 10 |
Dear Members,
Do you know why FLUENT uses the Hagesather or Ramkrishna method for breakage formulation? Couldn't we use the Luo formulation directly? Thanks in Advance, |
April 26, 2018, 21:55 |
#137 | |
shaham
Rep Power: 15 |
Thank you for mentioning the important point. Yes for the models that only have Ni and Nj in the model you do not need to find these values. but there are some models that either are defined independent from NI NJ or some other cases. As I remember I was trying a few cases of coalescence and breakage models just to check the results I faced that type of models. So still it might be needed.
I first used a case file, then found the for loop a better idea. I wanted to make the code read the bin values from a file! but I left PBM for DPM later and threw PBM into the garbage Regarding your question for the bins, I remember in the help it mentioned that for every interval it uses the lower boundary for calculation. Basically, for a bins 1mm,2mm,3mm, the code add any particle with diameter of 1-2mm for bin 1mm. You can check it in the help if I am right. In that case I think PBM uses the lower value of each bin for any other calculations Quote:
April 26, 2018, 22:02 |
#138 |
shaham
Rep Power: 15 |
1) I learned C in fluent, so that's the only way I found to compare two real values (convert them to integers and then compare)
2) What I wrote was for breakage I think. For coalescence you can get the bin number for d2 by adding another if-statement in the loop for d2 You are welcome |
April 27, 2018, 08:14 |
#139 |
nilesh
Rep Power: 9 |
We can choose any one of them. The point is Hagesather formulation requires minimum number of integral points and lower computational power. The accuracy is also comparable with that of Ramakrishna formulation.
April 27, 2018, 11:12 |
#140 | |
Masoud Ravan
Rep Power: 10 |
but my question is why should we choose one of them? Are they two methods of discretization of PBM or another thing..? |
Modeling porous media with FLUENT | newcomer | FLUENT | 4 | September 26, 2013 01:08 |
Loading of Temperature datas from ansys to fluent! need help!! | tensun | FLUENT | 0 | November 6, 2010 01:35 |
Import Soliworks geometry to Ansys Fluent 12.0 | nunolopes | FLUENT | 0 | October 7, 2010 12:24 |
FSI, Fluent Ansys coupling | Greg Carnie | FLUENT | 5 | January 7, 2010 20:15 |
Population Balance Theory | student | Main CFD Forum | 2 | August 10, 2008 05:12 |
