creating isosurface using journal file
Old   June 5, 2012, 04:33
Default creating isosurface using journal file
Santo
dsanthosh2 is on a distinguished road
Sir,
I have a long duct of 6 m length and I need to plot temperature at each 0.1 m length. I can do it manually through isosurface but takes long time. Like this I have to do for 20 different cases. So I need to write a journal file such that it creates an isosurface at each 0.1 m. Kindly help me in this regard.
Thank you.
dsanthosh2 is offline   Reply With Quote
Old   June 6, 2012, 08:22
delaneyluke is on a distinguished road
Hi Santosh,
Open Fluent window, Start recording the journal, read your case and data and create an isosurface for the first 0.1 m length, Stop your journal.
Now open the journal in a text editor and copy the isosurface creation command for the number of iso-surfs you need and edit the distance accordingly.
You can then use the same journal for multiple cases by changing the name of case file in the first line (rcd ...)
Hope this helps
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   June 7, 2012, 04:09
Santo
Dear Sir
Thank you very much for the informatio. It works. You have saved me lot of time.
Many thanks for your help.
-Santhosh
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
