In steady DPM model, how to get a particle residence time in a specific cell?
Old   June 1, 2012, 11:34
Default In steady DPM model, how to get a particle residence time in a specific cell?
Dan
DanK is on a distinguished road
Hi All,
In steady DPM model, how can I get a particle residence time in a specific cell?
I am trying to calculate the particle concentration by PSI-C (particle source in cell) method. To calculate the concentration, I really need to get the particle residence time in specific position.
Please help me to solve this problem.
Thanks.
DanK is offline   Reply With Quote
Old   August 25, 2012, 01:33
George Pichurov
jorkolino is on a distinguished road
Dong Hwa, is that you? If yes, I hope we solved your problem, if not, here is algorithm that you and others can follow.
in FLUENT 6.3 UDF Manual in chapter 3.2.7 you will find a lot of macros for DPM. I am mentiioning a few releveant here:
P_TIME(p): current particle time.
P_DT(p): current particle time step.
P_TIME0(p): particle time at entry to current cell.
TO get residence in current cell, I guess that the expression P_TIME(p)-P_TIME0(p) is needed.
The trick is, to be able to log this result over the particle track, i.e. to know at each point of the track what is the cell residence time. This is done with a macro called DEFINE_DPM_SCALAR_UPDATE. It is run each time the particle changes position.
DEFINE_DPM_SCALAR_UPDATE(dose, c, t, initialize, p)
	if (initialize)
		P_USER_REAL(p,0) = 0; /* this variable will hold the cell residence time, we initialize it here */
	else
		P_USER_REAL(p,0) = P_TIME(p)-P_TIME0(p) ; /* store the cell residence time into the variable */
Every particle has an array of variables, which variables hold data for the particle during its track (i.e. the variable value changes along the particle track). What you essentially do above is declare particle array variable [0] and use it to store the cell residence time in it. Now, after hooking that in FLuent, you will have extra property for the particle, cell residence time. To hook it, (1) declare one variable in the array by going to UDF tab in the DPM model and chose number of scalars = 1 (2) in UDF function field, the same tab, drop down the scalar update and hook the function.
If successful, you can color the tracks by their cell residence time, you can also manipulate this property. You can also store the cell index into a particle array variable, P_USER_REAL(p,1) = P_CELL(p);
By the way, after knowing the cell residence time how do you intend to calculate the concentration of particles in a cell? I am not very clear on that, but I'll need to do something similar and it will be nice to know.
jorkolino is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
dispersion model with lagragian particle tracking model for incompressible flows eelcovv OpenFOAM Running, Solving & CFD 54 April 10, 2018 10:36
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
How to put melting Point data of inert particle in DPM model subhankar_bhandari Main CFD Forum 0 July 26, 2010 08:28
Steady state DPM - Convergence and particle tracks Sandilya Garimella FLUENT 2 March 28, 2008 16:53
