Problem calcualting the mass flow entering each cell |
May 31, 2012, 16:24 |
javiercran
I have tried to calculate the mass flow entering inside a cell (for a DEFINE_SOURCE macro) with a loop over the faces of the cell but I have problems of "non-integer subscript expression: unsigned char". This is my code #include "udf.h" #include <mem.h> DEFINE_SOURCE(theta_momentum,c,t,dS,eqn) { //near peak operating point real Ft; //Ft source term real T01; //Inlet Total temperature real T02; //Outlet Total temperature real cp; //variable which will store the specific heat of air real x[ND_ND]; //array for storing the centroid position real pi=3.1416; real omega=16043*2*pi/60; real r; face_t f; real massflow=0; real volume; Thread *f_thread; int n; c_face_loop(c,t,n)//line 21 the one which gives problems {f=C_FACE(c,t,n); f_thread = C_FACE_THREAD(c,t,n); if(F_FLUX(f,f_thread)>0)// only calculate the massflow entering {massflow=massflow+F_FLUX(f,f_thread); } } massflow=massflow*2*pi;//axisymmetric volume=C_VOLUME(c,t); T01=288.15; cp=1006; C_CENTROID(x,c,t);//we store in x the centroid position of each cell r=x[1];// the radial position is the y-coordinate of the cell centroid r = x[1]; T02=1.164*T01; Ft=massflow*cp*(T02-T01)/(volume*omega*r); dS[eqn]=0; return Ft; } I need your help because I cant see the mistake I am doing. Regards |
Target Mass Flow Rate | Nitin | FLUENT | 9 | June 17, 2017 11:30 |
Problem of mass conservation in multispecies flow in porous media and T° gradient | pilou | FLUENT | 0 | January 31, 2011 09:19 |
CFX-Post: problem with mass flow | Markus | CFX | 5 | February 19, 2005 18:30 |
Target mass flow rate | Saturn | FLUENT | 0 | December 10, 2004 05:18 |
Problem on boundry of two phase flow | youngan | CFX | 0 | June 30, 2003 03:32 |
