Conjugate heat transfer
Old   May 30, 2012, 07:16
Default Conjugate heat transfer
Alireza
ali_1364reza is on a distinguished road
Hi Friends
I'm a Ph.D. student majoring in mechanical engineering, working on “Unsteady Conjugate Heat Transfer in reacting flow”.
I faced some questions about Fluent. I’d be so thankful if you could help me.
1. Does Fluent solve this problem (Unsteady Conjugate Heat Transfer in reacting flow)?
2. Which algorithms does Fluent use for conjugate heat transfer?
With Kind Regards
ali_1364reza is offline   Reply With Quote
Old   May 31, 2012, 10:38
James Willie
jwillie2000 is on a distinguished road
Hi Ali, I would suggest you should read the Fluent Manual. They have a full description of the way CHT was handled in Fluent. Critical I think is how the heat transfer coefficient is determined. Plus doing the tutorial on it might give you a good start. But u may not get a full CHT in Fluent since the solvers are not coupled I think.
jwillie2000 is offline   Reply With Quote
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid Rockda FLUENT 24 August 30, 2016 07:33
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Conjugate heat transfer and radiation modeling questions shankara.2 FLUENT 0 April 21, 2009 16:55
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
