Aluminium Plate Heated by Solar Radiation
Old   May 29, 2012, 14:45
Default Aluminium Plate Heated by Solar Radiation
James
Allankey is on a distinguished road
I am trying to model a solid aluminium plate that is heated by solar radiation and is cooled by a water pipe running along its length. The model consists of three domains, the air above the plate, the solid aluminium, and the water in the pipe. I meshed my model with the Ansys mesher as 1 part.
I am wondering if it is possible to achieve this simulation in fluent as I am getting some horrible back flow in both the water outlet and in the air domain. I am also unable to heat the solid using the solar load or DO irradiation models. I have the following questions:
1. Is it possible to set different initial values for each solid/fluid domain in fluent?
2. Is it possible to heat a solid using one of the radiation models and then remove this heat using another fluid?
3. Is the backflow problems a result of the boundary conditions I have specified? I am using a velocity inlet set at 1m/s for the air speed and my water speed is 0.1m/s. All the outlets are specified as pressure outlets. It seems that the solution converges through compensating the upper air domain with backflow in the lower water domain.
Many Thanks
J
Allankey is offline   Reply With Quote
fluent, solar collector
Solar radiation model Min Siemens 2 August 31, 2018 09:04
Modeling the flow of solar radiation as the heat flux from the surface. Gebbels FLUENT 0 March 25, 2012 15:39
S2S Radiation Solar Modeling Help yus310 ANSYS 0 September 20, 2011 15:10
Solar radiation though double glazing Multiband CFX 0 January 26, 2009 09:19
solar radiation su nam Siemens 0 July 30, 2004 03:17
