Drag & lift coefficients for a velocity inlet BC
Old   May 29, 2012, 09:50
Default Drag & lift coefficients for a velocity inlet BC
tsi07 is on a distinguished road
Hi everybody,
I have a circular wall with a velocity inlet boundary condition to input a particular velocity on it.
But now I need the drag (and the lift) coefficient.
Is anyone have an idea to take it or to calculate it ? I need to plot it.
I join a picture with stream lines to give an idea about the flow...
Thanks !!!
tsi07 is offline   Reply With Quote
Old   May 30, 2012, 07:05
Any idea ?
Otherwise, is someone have a method to calculate the Drag force ?
With a custom field function for example ??
Old   May 30, 2012, 09:45
rabbahs
shabbarraza2000 is on a distinguished road
go to
Report>result reports>reports>forces
here u can calculate
or u can also monitor them
solve>monitor>Drag or life
cheers
shabbarraza2000 is offline   Reply With Quote
Old   May 30, 2012, 09:52
Default the boundary condition is a velocity inlet
Yes I know this way, but I change the boundary condition to a velocity inlet,
so there is no wall in the window to choose, and so I have to find an other way.
Old   May 30, 2012, 09:59
rabbahs
hmmm ... no idea.
because for me, if their is no wall then their should be no drag of lift force.
try to generate two curves and take the pressure difference and calculate the coefficient manually
boundary condition, drag coefficient, velocity inlet, wall
VOF Volume fraction in Velocity inlet aruelle FLUENT 2 May 10, 2024 11:17
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 06:35
time varying inlet velocity Zhe Liu CFX 0 July 31, 2008 07:56
drag and lift coefficient Noé Siemens 5 July 13, 2004 11:21
pressure. lift and drag coefficients waqar mahboob Main CFD Forum 0 July 25, 1998 04:34
