how to improve convergence for fine mesh E-E model for fluidized bed? |
May 24, 2012, 03:12 |
cfd
Rep Power: 15 |
the convergence is 1e-8s! and takes ages (literally) to get 0.1s of simulation- its a solid bed with freeboard above and gas velocity inflow bc at bottom.
even 1e-7,1e-6s time step would make a huge difference. any tips?? |
October 7, 2012, 18:01 |
mohammad sadegh
Rep Power: 15 |
How many phases are there in your simulation? what is the number of transport equation which should being solved and the degree of coupling? hence, you should enter 1e-3 for absolute criteria of continuity, and enter 1e-5 for time step at first simulation, before this procedure you must simplify your problem.
October 9, 2012, 15:39 |
#3 | |
Maryam
Rep Power: 14 |
hi i am simulating a fluidized bed. i have a problem. there is reversed flow at outlet boundary and the solution does not converge. how can i solve this problem. Thank you in advance |
October 9, 2012, 16:34 |
mohammad sadegh
Rep Power: 15 |
be sure the gravity is activated
October 9, 2012, 16:39 |
Maryam
Rep Power: 14 |
October 9, 2012, 16:47 |
Maryam
Rep Power: 14 |
October 9, 2012, 16:52 |
mohammad sadegh
Rep Power: 15 |
yes it must be activated in operating condition panel
October 10, 2012, 06:45 |
Tamil Nadu
Rep Power: 14 |
Hello All,
I want to do analysis of heat transfer from water flowing through pipes submerged inside concrete. I am modelling in GAMBIT and wish to analyse it on Ansys FLUENT. Can anybody help me out, how to model and simulate? Does any tutorials exist? |
eularian-eularian model, fluidized bed, very slow convergence |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Influence of mesh refinement on the convergence | saisanthoshm88 | CFX | 6 | November 26, 2010 07:58 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Convergence problems with different mesh size | echo | Siemens | 10 | April 19, 2006 05:13 |
k-e model and mesh sensitivity | raj calay | Main CFD Forum | 13 | July 28, 1999 16:48 |
