Modelling solid within a fluid
Old   May 20, 2012, 23:33
Question Modelling solid within a fluid
clgs.1903 is on a distinguished road
Hi everyone,
I'm just getting started with FLUENT 14.0 (and computer simulations of fluid flows in general) so I hope this isn't too stupid a question. I'm trying to model the situation of having a solid sphere inside a cylinder in which fluid flows, and analysing the subsequent heat transfer to the sphere.
From what I understood, the way to do this is to create the cylinder, remove the sphere from the geometry using cut material, freeze the cylinder, and then add the sphere material back in. And then mesh, solve, etc.
However, this doesn't seem to be working for me. The fluid flow solves fine but it doesn't seem to recognise the heat flow across the fluid/solid boundary. I've read through the manual and the forums but there doesn't seem to be much help on this particular issue. If anyone has any suggestions they would be greatly appreciated.
Thanks in advance
clgs.1903 is offline   Reply With Quote
Old   May 21, 2012, 02:19
chg
chg is on a distinguished road
I think your way of creating geometry should work. Although I usually create cylinder > freeze> add sphere by slice material. Then in the bottom left that displays solid/fluid you may need to add the two into one part?
chg is offline   Reply With Quote
Old   May 22, 2012, 11:29
Hmmm alright I'll give that a shot, thanks for your help
boundary, geometry, heat
Solid to Fluid Heat Transfer Modelling Problem bortonj88 Main CFD Forum 3 November 14, 2011 15:21
Solid Fluid Interface boundary problems shankara.2 ANSYS Meshing & Geometry 0 April 22, 2009 17:05
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 04:12
Modeling of solid domains in fluent, no fluid flow Satish Perivilli FLUENT 2 December 1, 2005 12:41
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
