consfused to simulation water current turbin in fluent
Old   May 17, 2012, 06:18
Default consfused to simulation water current turbin in fluent
ibnu mulkan
mulkanindonesia is on a distinguished road
Hi , somebody please help me todo my simulation
i have already do testing and experiment with my vertical axis water current turbine and i have got RPM (radius per minute).I want simulate the turbine in Fluent to know what exactly happen with the flow that trough the turbine.
i have already draw the turbine with gambit.
the problem is , i don't know how to put the RPM value to set the Boundary condition in fluent
i have alrady try to put the RPM ( i have got RPM value is 72 in 1 m/s velocity of river)into the blade ( initialize as wall) on Moving wall rotational and input the value. the result of the contour of velocity is really bad. there is a red (high velocity near blade,very thin) whereas the velocity inlet is slow ( 1 m/s).
and the second try somebody tell my to make a new volume such a tube as a place for blade include in that volume, and the RPM value take into the moving reference zone in cell zone menu (rorating) to that fluid in tube fluid.
and i change the wall that interaction between tube fluid zone and river zone into a interior. and the last i change the blade wall boundary condition into moving wall but i m not take any value to that. so i remain in zero.
and the result is still i dont understand.. from velocity vector i got the water come out from rotate water.
so somebody plizz help mee
sensei teacher who experts in this field
please tell me where my mistake
THANK A LOT
mulkanindonesia is offline   Reply With Quote
Simulation of waves on a Water Surface Leech OpenFOAM Pre-Processing 27 May 22, 2015 02:19
Comparison between Solidworks Flow Simulation and Ansys Fluent Bruce828 Main CFD Forum 5 February 23, 2013 11:13
(help) three phase simulation on fluent sincity FLUENT 0 July 20, 2011 01:19
Can Fluent start a simulation from a negative time Ted Chu FLUENT 10 November 26, 2008 22:06
HELP!:CFD modelling using FLUENT in swimming pool Tee Main CFD Forum 0 September 7, 2005 21:48
