May 17, 2012, 02:54 |
3D Wing
samrat himvanth nanduri
Rep Power: 14 |
HI could any1 help me on how to assign pitch and yaw angles in fluent while running a simulation over a 3D wing. I want to assign both these values at the same time..
May 17, 2012, 03:59 |
Let say fuselage is in X-Y plane and wings along the Z-direction. In this case logntitudal axis is X and vertical one is Y. The Z-axis is pointing out of X-Y plane.
Pitch angle = alpha Yaw angle = beta Formulae are: Case 1: Only alpha (Beta = 0) X = Cos (alpha) Y = Sin (alpha) Z = 0 Case 2 : Only Beta (Alpha = 0) X = Cos (Beta) Y = 0 Z = Sin (Beta) Case 3 : Both Alpha and Beta (360 model) X = Cos (alpha) cos (Beta) Y = Sin (Alpha) Z = Cos (alpha) sin (Beta) http://en.wikipedia.org/wiki/Axis-angle_representation http://en.wikipedia.org/wiki/Yaw,_pi...93Bryan_angles http://en.wikipedia.org/wiki/Flight_...wing_aircraft) Last edited by Far; May 17, 2012 at 06:11. |
May 17, 2012, 04:13 |
#3 | |
Rep Power: 14 |
Thank you for the reply...it was really grateful..I wanted to ask you of where to apply these formulas.. in the boundary conditions while setting the inlet velocities or at any other place,,, |
May 17, 2012, 05:51 |
Rep Power: 14 |
hi thanks..i'm finding it a bit difficult assigning the values..cold you pls let me know the formula while the wing is in the Z direction
3D Wing Analysis | Ed | FLUENT | 5 | April 13, 2019 14:07 |
Forward swept wing simulation | abid | Siemens | 1 | June 16, 2012 14:26 |
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails | klausb | OpenFOAM Meshing & Mesh Conversion | 0 | December 28, 2011 15:26 |
[Gridgen] Blocking topology for blunt wing | siw | Main CFD Forum | 3 | July 21, 2010 14:55 |
multi wing element - negative coefficient of drag? | Zweeper | FLUENT | 10 | March 11, 2010 13:20 |
