Help, energy sources.
Old   May 14, 2012, 06:20
Question Help, energy sources.
qiang xia
alanlove is on a distinguished road
Hi
I want to add mass source, momentum source , energy source and species source into fluid .
One material(one species) was adding to fluid, its temperature is T, specific heat at constant pressure is Cp, enthalpy at reference temperature is h0. The mass source is a(kg/m^3).
I have a question, the energy source is?
Thank you.
alanlove is offline   Reply With Quote
Old   May 14, 2012, 12:18
mali28 is on a distinguished road
Originally Posted by alanlove View Post
Hi
Thank you.
You can use fluent multiphase model or discrete phase (lagrangian approach) to add particles in the fluid stream. Then add heat/mass exchange in it as well.
You can use the UDF function DEFINE_DPM_SOURCE if you want your own laws for heat, mass and momentum transfer.
mali28 is offline   Reply With Quote
energy in sonicFoam joern OpenFOAM Running, Solving & CFD 1 September 24, 2019 01:15
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 07:06
Setting Mass and Energy sources in fluent Amr FLUENT 6 February 23, 2006 07:36
UDF sources for energy equation el FLUENT 0 July 1, 2005 09:38
Energy sources Marko FLUENT 2 February 16, 2000 04:12
