liquid film separation
Old   May 14, 2012, 04:55
Default liquid film separation
Vitaliy
Feanor4ik is on a distinguished road
Hello, I'm trying to model separation of liquid film from the surface through the slit. Principal scheme is shown.
What kind of multiphase model and boundary conditions type should I use?
Feanor4ik is offline   Reply With Quote
Old   May 15, 2012, 02:43
delaneyluke is on a distinguished road
Use the VOF multiphase model.
At the inlet give the height of the water column, and specify volume/mass fractions at the outlets.
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   May 15, 2012, 06:27
Vitaliy
Regards
Luke
Thanks for the advice, but VOF model is not suitable, because phases must have different velocities (not 0 m/s).
Yours faithfully
Vitaliy
Old   May 15, 2012, 06:40
Then you would probably have to use the Eulerian model where a separate momentum eqn is solved for each phase.
Regards
Luke
Old   May 15, 2012, 06:58
Vitaliy
Regards
Luke
I tried this model, but in few iterations i got "Divergence detected". May be it is connected with the type of BC that I used? I used pressure-inlet and pressure outlet BC.
Besides, should I set volume fravtion distribution on inlet by simple profile or using UDF?
Yours faithfully,
Vitaliy
Old   May 26, 2012, 03:25
Felix
QustFelix is on a distinguished road
This is an very interesting subject. In fact ,I am doing some works about liquid films now,but I am not sure wether fluent can model this sort of problems or not,because the magnitude of thickness of liquid film maybe too tiny to meet the continuum fluid mechanics .But I am not sure about this,I am inverstgating about this. Before this I am using a software named Surface evolver .
Hope you can get an answer .
Regards
Felix
QustFelix is offline   Reply With Quote
Old   February 5, 2013, 16:17
Question Modeling droplet by surface evolver
alma is on a distinguished road
Does anyone have experience with droplet simulation by surface evolver?
alma is offline   Reply With Quote
simulation of liquid thin film Saman Main CFD Forum 4 March 11, 2018 01:55
Thin liquid FILM breaks with InterFOAM ovie OpenFOAM 5 June 25, 2010 14:18
VOF problem, liquid film thickness Pedro24 FLUENT 0 May 13, 2009 06:57
Liquid film Trond G. Grüner FLUENT 3 April 27, 2005 19:37
liquid film modeling David Carnaga Main CFD Forum 2 July 18, 2002 22:07
