May 12, 2012, 18:26 |
HELP TIME on FLUENT
slim
Rep Power: 14 |
hello,
I simulated a fluid flow in a straight pipe with ANSYS Fluent : Inlet velocity : 0.116 m/s Outlet pressure 400 Pa with mass flow rate 0.063 kg/s Time step size: 60 seconds Number of time step: 5 Number of iterations / time step: 300 I find the same result I noticed that the solver resolves five blocks of 300 iterations each time, is it recalculates every time? 60 seconds is enough or must I fix a few minutes thank you very much |
May 12, 2012, 19:37 |
#2 | |
Lucky
Rep Power: 66 |
isn't this a steady problem? none of your boundary conditions appear to be transient, your simulation will be steady even if you run a transient simulation. |
May 13, 2012, 06:04 |
slim
Rep Power: 14 |
hello,
I try to simulate flow between two cylinders. Normally I should get a constant velocity profile along the length (figure 1). Fig 1.gif But, I found an acceleration along the entire length of the cylinder (figure 2). Fig 2.gif Change speed / length axis> 0 normally it must be = 0 I can not find the trick. Is that it's normal? thank you |
cfd, flow, fluent, pipe flow, time |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Time Scale in Fluent | Andrew | FLUENT | 0 | April 20, 2009 02:24 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 16:15 |
Time Step Size for Airfoil Model - Fluent | Prateek | Main CFD Forum | 0 | November 4, 2004 19:42 |
