May 4, 2012, 03:54 |
3d centrifugal pump analysis in fluent_turbo
manuvel
Rep Power: 17 |
Hi....
I have been working in the flow analysis of centrifugal pump. I tried to enable the turbo topology in fluent but was getting error "Not Valid Topology: Not defined" I am doing a full impeller attached with the casing analysis. i have defined the following boundary condition for turbo topology HUB - hub CASING - shroud THETA PERIODIC - THETA MIN - THETA MAX - OUTLET - impeller interface with casing BLADES - impeller blades for the full 3D analysis should i specify any theta min and max could any one help me...... Thanks in advance Manuvel |
Flow analysis for a centrifugal pump | raj | CFX | 3 | September 30, 2016 03:23 |
CFD analysis of Centrifugal pump at shut off condition | Nitin Dewangan | CFX | 2 | February 10, 2012 19:48 |
CFD analysis of centrifugal pump | saurabh9978 | FLUENT | 1 | April 6, 2010 06:40 |
CFD analysis of centrifugal pump | saurabh9978 | FLUENT | 0 | March 21, 2010 13:07 |
centrifugal pump cfd analysis | shatruhan lal | FLUENT | 1 | November 6, 2003 07:23 |
