Desperate HELP please: Vortex Shedding not showing circular cylinder
Old   May 1, 2012, 09:00
Exclamation Desperate HELP please: Vortex Shedding not showing circular cylinder
Michael
u50mb9 is on a distinguished road
Hi I've been stuck at the same point for 2 weeks and really need help.
My vortex shedding behind the circular cylinder is not showing. I am running a 3d, LES model with smaller mesh closer to the cylinder. I feel I may have made a simple error somewhere but I cant seem to correct it.
Using a time step of 0.0001 with 400 time steps with non-iterative advancements. Also using PRESTO, PISO and Bounded Central differential Momentum
What viscosity ratio and intensity should I use? The user guide seems to be very complex.
ANY advice is welcome. Please help my thesis is due shortly and I need to verify this model.
u50mb9 is offline   Reply With Quote
Old   May 1, 2012, 10:13
xrs333
xrs333 is on a distinguished road
you are modeling Karman vortex street phenomenon, so you have to make it sure that it will emerge, the key is Reynolds Number.
xrs333 is offline   Reply With Quote
Old   May 1, 2012, 10:19
Michael
Thanks for your reply, I'm using a Re of 1.4 x 10^5 but I cannot see the vortex street after 100 Iterations. Any suggestions how to correct this?
Old   May 1, 2012, 14:56
xrs333
have you estimated the vortex shedding frequency?
Old   May 1, 2012, 15:22
Lucky
what???? You are running LES, there is no viscosity ratio and intensity.
For LES, is your solution turbulent? One problem that often occurs with LES is that the solution relaminarizes.
Also, what's the relative time, non-dimensionalized? i.e. How much is 400 iterations?
How was your initializing? If you didn't initialize your flow with a RANS solution, expect it to take more time to develop into the proper flow field.
Old   May 1, 2012, 16:48
Michael
When setting my velocity Inlet, I chose spec. method of turb intensity & turb viscosity ratio.
I've been told to use a non-dimensional time step of 0.005.
I didn't initialize with RANS but I will try that now. When setting up RANS how do I know what kinetic energy and diss rate factors to use?
Kind regards
Old   May 1, 2012, 19:23
Lucky
Kind regards
Okay I see. With that method you do specify an intensity and viscosity ratio. You should know those parameters, they are your inflow conditions.
With no initialization, I would not expect to see any meaningful features before t=1, I would wait until t=10 but you can perhaps maybe see some structures develop by t=2, it is possible. With RANS initialization, it will be much quicker (so perhaps t=2 if RANS is used). Don't waste time to do the RANS initialization now, it is better to just keep iterating with the solution that you already have computed. Keep in mind that the solution is not time-accurate until the effect of the initial conditions has completely been removed from the computational domain (probably t~10, or more).
Again, with LES, always check to make sure your solution didn't relaminarize and that it makes sense. Just look at your velocity for the current timestep.
Also, disable the non-iterative time advancement if possible.
les model, turbulent flow, vortex shedding
Cylinder vortex shedding (3D) Apocolapse STAR-CCM+ 2 April 3, 2014 21:33
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
3D cylinder and Vortex Street shedding issues josik_1982 FLUENT 2 July 17, 2010 11:19
Vortex Shedding Circular Cylinder Ray Mahon Main CFD Forum 1 March 15, 2002 00:38
LES: vortex shedding past a 2D and 3D circular cylinder Rocchi Daniele Main CFD Forum 7 April 9, 1999 13:05
