April 27, 2012, 06:29 |
Radiation through vacuum with s2s model
Andrea
Rep Power: 16 |
Hi everybody,
I am simulating a particular counterflow heat exchanger constitued of two coaxial tube; in the outer tube flows the hot fluid, in the inner tube flows the cold fluid. This two tubes are separated by a gap in which high vacuum is created; heat is transfered in this gap through radiation (i'm using the s2s model). My problem is: Is it possible to create void cells in fluent? (I mean cells with no materials associated, in which no equation is solved and the heat is transferred only via radiation from surface to surface). Thank you in advance, Andrea |
April 27, 2012, 13:41 |
#2 | |
Lucky
Rep Power: 66 |
For void cellls. It is better not to do this in Fluent. Your geometry and mesh should have already taken care of the void cells when you first generated it. But if you really want to suffer the pain... In Fluent, you can cut up your mesh into regions and then delete the unwanted regions (your void cells). You then apply symmetry boundary conditions to the remaining exposed faces. Another way to do it is to separate the problem into different zones and do a similar trick. You can disable the computation of entire zones so that no equation is solved for that zone. But you have to be careful not to remove the walls of the heat exchanger. Keep in mind that Fluent is meant to solve Fluid Flows. Hence it is not a good solver to use if you just want purely s2s radiation (that is more of an algebra problem). |
April 27, 2012, 14:07 |
Andrea
Rep Power: 16 |
First of all thank you for your reply,
I use fluent because I also have to solve the convective heat transfer Can you please explain me how to disable the computation for one zone? Andrea |
April 27, 2012, 14:15 |
Lucky
Rep Power: 66 |
April 30, 2012, 09:31 |
Andrea
Rep Power: 16 |
Thank you again,
can I ask you another question? I'm solving the problem in exagonal symmetry; when the solution reaches the steady state I expect that the power exchanged by cold and hot fluid to be in balance (namely the product (mass flow rate)*(Cp,out*Tout - Cp,in*Tin) is the same for the two fluids) but this doesn't happen. Do you believe this can be related to problems with the symmetry boundary condition? Regards, Andrea |
April 30, 2012, 15:49 |
Lucky
Rep Power: 66 |
There shouldn't be any problems related to the symmetry, so no. Double check your calculations / make sure your solution is well converged. If the energy balance isn't coming out right then it's probably not converged.
November 1, 2012, 17:23 |
sagila
Rep Power: 14 |
I also need to model radiation through vacuum enclosure with s2s model. But, my case has only one zone and when I deactivate it, the walls of it are also removed! Is it possible to have the walls of the zone and deactivate the zone simultaneously? Thanks in advance. |
June 11, 2013, 15:35 |
sudhir
Rep Power: 17 |
hi sagila,
FLUENT requires a fluid domain next to surface for S2S radiation.Dont know why.. |
heat exchanger, radiation, s2s radiatiation model, vacuum |
Solar radiation model | Min | Siemens | 2 | August 31, 2018 09:04 |
How model radiation of both solid wall and fluid£¿ | Harry Qiu | FLUENT | 2 | February 4, 2013 00:04 |
Radiation Model - Spectral Model | Ray | CFX | 3 | April 10, 2006 10:33 |
definition difficulty-->DO radiation model | Harry Qiu | FLUENT | 0 | March 29, 2001 10:19 |
RE: Radiation model | Ashutosh Joshi | FLUENT | 1 | January 30, 2001 11:50 |
