April 27, 2012, 00:28 |
help needed : 2d water flow in heated pipe
abuabdellah
Rep Power: 13 |
i want any help about problem we took in exam
the problem is pipe length 3m diameter 2.54 cm its temperature 80c water velocity at the inlet 2.5 cm/sec temperature 60c the doctor wants us create the mesh on pointwise and solve it on fluent any help will be totally appreciated thank you in advance |
April 27, 2012, 02:25 |
Lucky
Rep Power: 66 |
April 27, 2012, 05:34 |
#3 | |
Felice
Rep Power: 16 |
F |
April 27, 2012, 10:29 |
i hope i could do it
abuabdellah
Rep Power: 13 |
LuckyTran really i hope i can do it
the problem that i am totally newbie for all of this so many thanks for your help !!! felicemastronzo many thanks really, i appreciate your reply you said that "There is a fluent tutorial that is exact your problem" can you tell me where can i find it ? many thanks .. |
April 28, 2012, 04:09 |
AHMAD
There is a tutorial that is similar to your problem on this site : https://confluence.cornell.edu/displ...ced+Convection I hope that this tutorial is useful to you. Last edited by A7A; April 28, 2012 at 16:43. |
May 2, 2012, 14:44 |
thank you
abuabdellah
Rep Power: 13 |
thank you
i will see what i can do |
May 4, 2012, 04:10 |
#7 | |
Felice
Rep Power: 16 |
http://hpce.iitm.ac.in/website//Manu...pdf/tg/pdf.htm F |
problem with two phase flow (air injected in water) | miles_davis | OpenFOAM | 15 | March 31, 2021 10:36 |
Periodic Pipe Flow LES | dvolkind | CFX | 8 | March 21, 2020 06:30 |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 22:25 |
fsi model of water flow in a pipe | alinik | CFX | 11 | November 5, 2009 12:29 |
Turbulence in a pipe flow | JM | Main CFD Forum | 4 | December 21, 2006 05:04 |
