April 26, 2012, 12:52 |
Problem with periodic boundary conditions
Rep Power: 14 |
Hi all
I am a PhD student, and I'm new in ansys fluent. I am trying to simulate a 2D airfoil with periodic boundary conditions. As you can see in attached picture, the left and right boundaries are periodic, and the top and bottom boundaries are defined as outflow. What I want is to consider the output of first iteration as the input of the second iteration. I tried to perform some simulations, with translational motion, but the results make no sense. Can you help me??? I performed some simulations with "fixed" wing airfoil, and the results went fine. I am using the same turbulence model, but I am sure that the problem is in the definition of periodic boundary conditions. How to define the periodic boundary conditions, correctly? The final objective is to take into account the losses due to the airfoil wake. In addition, I attached some pictures of my previous results with periodic boundary conditions, in case it helps to identify the problem. Many thanks in advance |
April 26, 2012, 15:06 |
#2 | |
Lucky
Rep Power: 66 |
At best, your boundary conditions leaves the problem underdefined. As you have outflow with no inflow. The only stable solution is no flow! Can you clarify what you mean by output of first iteration as the input of the second iteration? In the process of iterating, this is exactly what is done. The output of the first iteration is used as the input to the second iteration. |
April 26, 2012, 16:27 |
Rep Power: 15 |
I agree with LuckTran, so please provide some more information.
Could it be, that your two outflows (guess flow is from let to right) should be something like a pressure-far-field? |
April 26, 2012, 18:34 |
#4 | |
Rep Power: 14 |
Ok, I will try to provide you some more information. The loop of flow is from left to right. (at the periodic boundary conditions, I defined a favorable pressure gradient of 100Pa. I was trying to simulate a helicopter rotor (or other kind of rotor). Is there any other way to simulate that kind of stuff in 2D? In this way, I was trying to take into account the wake losses due to the interference of the previous airfoil. And have many airfoils one after anothers is exactly what I want. When I say that "What I want is to consider the output of first iteration as the input of the second iteration" I mean that values of first iteration in right periodic boundary condition, will be the input values for second iteration in left periodic boundary conditions. Anyway, if you can explain me other simple way to simulate a rotational motion in 2D, I will be very gratefull |
April 26, 2012, 18:38 |
#5 | |
Rep Power: 14 |
And you are right, I am trying to simulate the flow from left to right! Thanks in advance |
April 26, 2012, 22:27 |
Help me,please!About the periodic boundary condition.
Small Mayi
Rep Power: 14 |
hello everyone:
i have a similar problem when reading a reference about porous meida.In order to be convinent for your reading and understanding the means.This paper was appended at the end of this text. Now i descripe my question.This paper's auther make a periodic boundary conditions to simulation the effective thermal conductivity,in which he impose a temperature drop on the periodic boundary according to his cited reference [20].While when i see the cited reference 20,finding that,i need to modify the coefficient matrix of the discreted equations,yet this is just my guess. Can you give me some suggestion on how to carry out this boundary using the fluent? Any help will be appreciated! Have a nice day ,my friend! oh,sorry because the Max Filesize limit,i cannot upload the reference on to the forum.If you want to know more detail pleas load from this URL: http://scholar.google.com.hk/scholar...ed=0CB0QgQMwAA Title:A numerical technique for computing effective thermal conductivity of fluid-particle mixtures HELP ME MY FRIENDS!!! Email :chenzhana@163.com |
April 27, 2012, 01:19 |
#7 | |
Lucky
Rep Power: 66 |
April 27, 2012, 02:32 |
#8 | |
Small Mayi
Rep Power: 14 |
Write this help i only consider that the common key words could arise much more attention, and no other hostility. I appologize for that! sorry again! |
2d airfoil, ansys 13, fluent 13.0, periodic bc |
Periodic boundary conditions in 3D Eulerian granular flow simulations | dsm | FLUENT | 4 | March 2, 2012 19:04 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
3D non-conformal periodic boundary conditions | Simon Riverin | FLUENT | 4 | February 23, 2007 01:35 |
Problem with Boundary conditions | Mahiboobswamulu | Main CFD Forum | 10 | August 26, 2003 13:24 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
