Simple Model Problem (Reversed Flow)
Old   April 26, 2012, 01:45
Default Simple Model Problem (Reversed Flow)
dom
Dominic Ow
dom is on a distinguished road
Dear all, I am trying to obtain the velocity streamline for a ventilation system and I have generated a simple 5m by 5m room with a protruded squared surface that represents the air-conditioning system. The general idea is to observe the streamline pattern as it fills the room and exits through the window. However, the flow profile doesn't behave as expected as it 'creeps' through the walls rather than filling the empty room spaces. Please advice!
Uploaded with ImageShack.us
dom is offline   Reply With Quote
Old   April 26, 2012, 02:16
mj
doctor evil is on a distinguished road
I think your simulation didn't reach convergence (see legend of the left top, do u think the velocity in your problem will be higher than 1e2m/s)
doctor evil is offline   Reply With Quote
Old   April 26, 2012, 02:24
dom
Dominic Ow
Many thanks for the swift reply doctor evil. No, of course it wouldn't be that high. (that said, I don't know how it got that value, my inlet velocity was set to 5 m/s) Also, How do I ensure convergence has occured?
Old   April 26, 2012, 05:37
Daniel Tanner
Daniel Tanner is on a distinguished road
Are you sure that the size of your room is what you think it is? If it is a cm to meter difference this might explain why the velocities are high. Check the domain size in the scale dialogue.
Daniel Tanner is offline   Reply With Quote
Old   April 26, 2012, 06:01
Sixkillers is on a distinguished road
Moreover what boundary condition do you use for outlet? What turbulence model do you use? Is it isothermal case? Also some information about mesh would help us (Mesh -> Info -> Quality, Mesh -> Info -> Size).
At least values of residuals for continuity and velocity should be below 10^-3. For energy it is 10^-6. However more important is to monitor quantities, which have physical meaning. For example, for your problem it could be mass flow of air on inlet and outlet. Difference between them shouldn't be higher then several percents.
Sixkillers is offline   Reply With Quote
backflow, fluent, streamline, velocity, ventilation
Help: apply B.C. in my granular flow model ? Derek Jing FLUENT 1 January 8, 2020 22:38
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Reversed flow on external aero problem Ben FLUENT 2 August 22, 2006 11:05
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
