April 24, 2012, 03:39 |
Parallel FLUENT received fatal signal
Dramjet
My Environment:
Windows 7 x64 Intel Core i7 2630 8GB Memory FLUENT 14.0 Parallel FLUENT works well, but When exit , FLUENT create cortexerror.log file: Error [cortex] [time 4/19/12 22:55:53] Parallel FLUENT received fatal signal () 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Serial FLUENT no such error. |
April 24, 2012, 13:27 |
#2 | |
Lucky
Rep Power: 66 |
Are you able to iterate at all or does it start iterating and then quit after a few iterations? Usually I get this error if, the license server becomes disconnected after Fluent launches. |
April 30, 2012, 03:44 |
Dramjet
I've had this happen to me only when the FLUENT exit, but
in Windows xp 32bit environment, fluent works fine! |
April 30, 2012, 04:19 |
This could be the issue of not installing MPI as a setup of ANSYS 14. The error you mentioned often comes due to the less memory. Please make suer that you have enough disk space and memory to run FLuent.
Chao |
How to remove the error:FLUENT received a fatal signal (SEGMENTATION VIOLATION). | Conan | FLUENT | 9 | December 20, 2019 13:31 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 16:41 |
FLUENT received fatal signal (ACCESS_VIOLATION) | Henry | FLUENT | 2 | August 31, 2007 06:11 |
Fluent Parallel SUPPORT | MOHAMMED TOLBA | FLUENT | 1 | February 20, 2006 02:27 |
Parallel Fluent on Linux clusters | Chengwang Lei | FLUENT | 3 | November 24, 2004 03:05 |
