Along which direction is the lift coefficient
Old   April 22, 2012, 16:40
Cool Along which direction is the lift coefficient
djan is on a distinguished road
Hi im doing a 2D CFD case for a NACA foil pitching and heaving. Was just wondering if the lift coefficient given by fluent is normal to the inlet flow or normal to the moving foil at that time instant. Thank you.
djan is offline   Reply With Quote
Old   April 22, 2012, 19:32
Lucky
The user inputs for Drag and Lift coefficient will ask you to input the force vector. The drag and lift coefficients are then calculated with respect to this inputted vector regardless of what the inflow conditions are.
Old   April 23, 2012, 20:32
Thank you for replying. So if i input to calculate lift for the foil, it will be normal to the foil and and not respect to the x and y velocities in the global coordinate at that instant. Hope this is what you mean.
Old   April 23, 2012, 23:29
Lucky
No. Read my words again. It will calculate it with respect to the vector that you input.
It does not care what the global x, y, or local surface normal is.
cfd, fluent
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 17:50
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Zero Coefficient of Lift Problem MH FLUENT 0 February 25, 2007 12:48
Lift force or coefficient of lift Rola FLUENT 1 November 12, 2006 14:29
drag and lift coefficient Noé Siemens 5 July 13, 2004 11:21
