How to specify a mixture of gases at inlet boundary condition?
Old   April 22, 2012, 15:16
Default How to specify a mixture of gases at inlet boundary condition?
Andrius
Matlab69 is on a distinguished road
Hi guys,
I am trying to specify at inlet boundary conidtions that I have a mixture of gases entering the domain - x kg/s of methane and y kg/s of air, for example. However, I am only able to choose one gas for the inlet...
Matlab69 is offline   Reply With Quote
Old   April 23, 2012, 00:29
vagaikwa is on a distinguished road
is it possible for you to split your inlet in two parts? so that you can enter both the fluid velocities.
vagaikwa is offline   Reply With Quote
Old   April 24, 2012, 06:17
Andrea
Andrea1984 is on a distinguished road
I'm not sure about this, but if you're using the VOF model, you should be able to specify the volume fraction of each phase at the inlet (if you have a velocity inlet, velocity is the same for the two phases so knowing the different densities you should be able to specify the flow rate).
Hope this can help,
Andrea
Andrea1984 is offline   Reply With Quote
Old   April 24, 2012, 07:08
delaneyluke is on a distinguished road
There are 2 ways. If it's a homogeneous mixture (no discrete phases) you can use the species transport model and define your mixture with mass fractions of individual components.
If it's a inhomogeneous mixture (discrete phases) then you can either use the Multiphase-->Mixture model or Multiphase-->VOF model and define the volume/mass fractions of your 2 phases at the inlet.
Regards
Luke
delaneyluke is offline   Reply With Quote
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 17:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
inlet boundary condition swe704 FLUENT 4 June 3, 2009 17:58
outlet to inlet boundary condition assighna CFX 1 May 11, 2007 00:36
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
