April 22, 2012, 07:42 |
force monitors
le
Rep Power: 17 |
I use the FLUENT 13 to simulate VAWT. The output required is torque, hence, I use the force monitors to checking the moment coefficient with flow time. I enable three options: print, plot, write to file. However, I did not get Cm-history file while I can have the the value of Cm (from print option) and graph of Cm (from plot option). What I need is the Cm-history file. Could someone help me to handle it, please. Thanks, |
April 22, 2012, 19:45 |
#2 | |
Lucky
Rep Power: 66 |
Are there any other errors? If fluent does not have write privileges in the local directory (it can happen) then it will not be able to write the output file. But I think that should have set off an error. To double check that it is correctly outputting: If you close the case-data file and then reopen it at a later time and start iterating again, before it starts to iterate there should be a prompt asking you if you want to append to the previous data or overwrite. Are you getting this prompt? If you do not get the prompt, the next thing to do would be to create any text file and save it with the exact same name as you named the output file. Store this file in the local working directory. Now when you go to iterate it should definitely prompt for append, because the file is definitely there (you just put it there). |
April 24, 2012, 21:31 |
force monitor
le
Rep Power: 17 |
Thanks so much Lucky Tran
I found this....as you said "It will be saved in the local working directory"... |
fluent, monitor file |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Initialising Force Monitors | stuart23 | Fluent UDF and Scheme Programming | 2 | September 5, 2011 15:04 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 11:25 |
floating operating pressure and monitors force | Lavastre jeremie | FLUENT | 2 | September 7, 2007 09:10 |
Force monitors | Phil | FLUENT | 1 | June 4, 2004 03:21 |
