derivative for 2D axisymetric model
Old   April 3, 2012, 09:46
Question derivative for 2D axisymetric model
tsi07 is on a distinguished road
I'm trying to write a UDF which use derivative in a 2D axisymetrical model.
I wonder if there is a command like "C_DUDX" for Radial an Axial velocity which get back that velocities for the concerning cell.
Thanks for your answer !!
tsi07 is offline   Reply With Quote
Old   April 3, 2012, 11:06
Maybe it's the same thing and Fluent know that when I write C_DUDX, I want the axial-velocity derivative for x (the axial variable).
What do you think ?
Old   April 5, 2012, 13:33
I don't have any answer from users
My udf doesn't give an error message, but I don't have what I want as result from the post process. So there is a problem and I wonder if it's from the command C_DUDX used to take the axial velocity derivative for x.
Can someone help me to know how can I make a variable with the name "new_velocity" as the axial-velocity for example?
The idea is to compare my new variable(make with the command C_U) with the real axial velocity?
Thanks !!
Atomization and Breakup model xck1986 OpenFOAM 4 May 31, 2014 05:43
eddy dissipation model: combustion doesn't occur roukaia FLUENT 0 December 24, 2011 10:10
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 16:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 11:27
