November 1, 2012, 17:27 |
#21 | |
Vidit Sharma
Rep Power: 14 |
I tried to compile the UDF in fluent but it is showing some error as given below that i am not able to solve. "Deleted old libudf\ntx86\2ddp\libudf.dll The system cannot find the file specified. The system cannot find the file specified. (system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 file(s) copied. (chdir "libudf")() (chdir "ntx86\2ddp")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file. Done." Is anything i can do to eliminate this?? regards. |
November 1, 2012, 18:40 |
#22 |
Rep Power: 15 |
Hi!
Well, .c is the file type in which UDFs have to be saved. For the .h header file I assume that it is asking you for the #include "udf.h" command. and for dynamic meshes you have to add #include "dynamesh_tools.h" as well. I don't know if this helps you at all as these are basic things reagrding UDFs...as for regarding ''nmake'' problem which I've not yet come across I found this thread: http://www.cfd-online.com/Forums/flu...ues-nmake.html hope it helps. |
November 2, 2012, 07:57 |
#23 | |
Vidit Sharma
Rep Power: 14 |
I have tried so many ways to compile the UDF on windows 64 bits, then I did not get anywhere. I still have this error, What should I do, Please let me know the details. Deleted old libudf\win64\2d\libudf.dll 1 file(s) copied. (system "copy "C:\PROGRA~1\ANSYSI~1\v130\fluent"\fluent13.0. 0\sr c\makefile_nt.udf "libudf\win64\2d\makefile" ") 1 file(s) copied. (chdir "libudf")() (chdir "win64\2d")() # Generating ud_io1.h time_step.c # Generating udf_names.c because of makefile time_step.obj udf_names.c # Linking libudf.dll because of makefile user_nt.udf udf_names.obj time_step.obj Microsoft (R) Incremental Linker Version 9.00.30729.01 Copyright (C) Microsoft Corporation. All rights reserved. LINK : fatal error LNK1104: cannot open file 'kernel32.lib' Done. |
November 2, 2012, 23:27 |
#24 |
Rep Power: 15 |
Hi!
Well at this point there is not much I could suggest. I have to admit, my experience in writing UDFs is not very vast. But from kernel32.lib trouble I would assume there is something wrong with the way you compile. Therefore I would suggest a manual I used to get Fluent on 64bit win7 accept compiled UDFs. check if what you do is ok regarding this (as there might be some problems if you don't set the compiler correctly-32 instead 64 bit): http://www.cfd-online.com/Wiki/Fluen...ows_7_64bit.3F |
October 21, 2013, 04:14 |
#25 |
Marie
Rep Power: 13 |
hello,
I know that this post is quite old, however I have the same problem with the cylinder error. Did you solve your problem ? thanks |
October 21, 2013, 04:37 |
#26 |
Rep Power: 15 |
could you describe at first the geometry(axisymmetric, 3d, ...)-there was a suggestion here that define_cg_motion might not be an appropriate udf for such simulations. for me it was, but maybe for someone else's geometry it is not. I assume that in such way, a better response can be found faster.
October 22, 2013, 06:11 |
#27 |
tran trung
Rep Power: 13 |
hi
how to fluent message error ? |
October 22, 2013, 06:17 |
#28 |
Rep Power: 15 |
sorry, but I do not understand your question-can you re-post it as I think you left something out of it.
May 9, 2014, 10:14 |
#29 |
Khalid Ansari
Rep Power: 12 |
hi guys
will some1 please help me. i m also working on flow past a cylinder and my cylinder wall is rotationally oscillating. i want to write a program for that but i dont know how to write it so some1 pls help!!!!!!!!! |
April 9, 2015, 02:01 |
#30 |
sanjeet Limbu
Rep Power: 11 |
Dear frds
I am trying the rigid body motion in CFD fluent but UDF is showing error in preview. Warning unable to read the motion history i got the following lines for UDF velocity : #include "udf.h" #include "dynamesh_tools.h" DEFINE_CG_MOTION(oscillate, dt, vel, omega, time, dtime) { Thread *t; face_t f; /* define the variables */ t = DT_THREAD(dt); /* get the thread pointer for which the motion is defined */ /* if (!Data_Valid_P()) /* return; /* check if the values of the variables are accessible before you compute the function */ begin_f_loop(f, t) /* loop over each face in the zone to create an array of data */ { if (time <= 0.012) vel[0] = (643* time); /* define the velocity of the moving zone---*/ else if (0.012 < time < 0.019) vel[0] = vel[0] + (0.057 * time); else if (0.019 < time < 0.027) vel[0] = 14; else if (0.027 < time < 0.03) vel[0] = vel[0] - (0.162*time); else if (0.03 < time) vel[0] = 0; } end_f_loop(f, t) } I tried using the profile but the displacement is not meeting the 254mm as i mentioned in profile... Please help to get this error |
April 9, 2015, 13:05 |
#31 |
sanjeet Limbu
Rep Power: 11 |
I am trying to move using the folowing UDF
getting the warning that its unable to read the file #include "udf.h" DEFINE_CG_MOTION(oscillate, dt, vel, omega, time, dtime) { Thread *t; face_t f; /* define the variables */ t = DT_THREAD(dt); /* get the thread pointer for which the motion is defined */ /* if (!Data_Valid_P()) /* return; /* check if the values of the variables are accessible before you compute the function */ begin_f_loop(f, t) /* loop over each face in the zone to create an array of data */ { if (time <= 0.02) vel[0] = (673* time); /* define the velocity of the moving zone---*/ else if (0.02 < time < 0.027) vel[0] = 14; else if (0.027 < time < 0.03) vel[0] = 3 - 2800*(time-0.03); else if (0.03 < time) vel[0] = 0; } end_f_loop(f, t) } |
January 5, 2016, 13:53 |
Regarding the dynamic mesh
#32 |
jessy dayal
Rep Power: 12 |
Hello there .., I'm simulating a flow through a c-d nozzle....I need a help for simulating a pintle (wall boundary), which moves translational (along linear axis only) along the axis of the nozzle ...The pintle moves transnationally along x axis from the point near throat towards the upstream boundary ...
What are the options in dynamic mesh should I use ?? Is there any udf required, if yes, I needed help to write it ... |
January 6, 2016, 17:46 |
#33 |
Rep Power: 15 |
Hi!
Firstly, I'd ask, just to know if I got it correctly, is this like an injector with a needle in it? Or is it something else? Years ago I did an udf for a case where we had a horn moving up and down, like a piston. So, I might be able to say something more if your case is similar to mine (hence the given question). But I honestly need to take a look at what has been done exactly to comment more. regards |
January 7, 2016, 11:02 |
regarding udf
#34 |
jessy dayal
Rep Power: 12 |
Hello komon,
Its a kind of similar to your explanation for an injection. It's like a cylindrical rod being inserted into a nozzle (along the nozzle central line), so as to control (choke the flow) the mass flow rate which in turn will control the thrust ....I'm simulating this case in 2D ... If you have a model udf which uses the transitional movement of the wall boundary condition ...id be grateful for it .... Boundary conditions are an Axis, nozzle inlet, nozzle wall, pintle (moving wall), farfield. The cylindrical rod (pintle) would move about 26 mm backwards from nozzle throat (extreme downstream position) towards nozzle inlet . |
January 7, 2016, 11:56 |
#35 |
Rep Power: 15 |
Hi!
So, here's the UDF I used to make a moving wall boundary condition. I used the DEFINE_CG_MOTION udf. With it I moved the horn up and down in our domain, so I'd say you can easily change it to describe movement of your part. As you can see, you just need to put your movement into the vel[0] variable. Code:
DEFINE_CG_MOTION(sonotrode,dt,vel,omega,time,dtime) { Thread *t; face_t f; /* define the variables */ t = DT_THREAD(dt); /* get the thread pointer for which the motion is defined */ begin_f_loop(f,t) /* loop over each face in the zone to create an array of data */ { vel[0] = ; /* define the velocity of the moving zone---*/ } end_f_loop(f,t) } This would be my advice, I'm just sorry that I cannot access the fluent now to really check how exactly I did this. What I'd say is-try and see. But since the mesh is considered as rigid body and I think that I made it move with the horn, please check how this affects your mesh at the outlet or walls etc. I fear it might make some negative volumes there if the mesh is very refiened at the walls/outlet (our case was pretty specific and didn't need to be refined at walls at all). hope this helps |
January 10, 2016, 02:24 |
regarding udf
#36 |
jessy dayal
Rep Power: 12 |
hello komon, thanks for posting the udf ....but im facing the interpretation error ....
its showing that line 8 .....it is this one ( t = DT_THREAD(dt); /* get the thread pointer for which the motion is defined */ ), comment says that structure reference not implemented ... And which one of the three dynamic methods should i use for my problem (smoothing, layering,etc) . |
January 10, 2016, 05:27 |
#37 |
Rep Power: 15 |
hmm, never got that error. Maybe you need to define something regarding the boundary or the inside of the domain. did you choose them as rigid body?
for the rest, I fear I cannot really say, since I have no access to fluent atm to check which method was done. Let me see some things, if I have this noted somewhere... |
January 10, 2016, 16:53 |
#38 |
Rep Power: 15 |
hey,
actually, I just figured I do have access to fluent. so, sorry for the mistake on my side, I thought fluent is not available on the machines I use. regarding the mesh, my setting was to layering and remeshing. in the settings, I chose ratio based factor of 0,5 for layering and local cell for remeshing (max cell skewness of 0,7 I see is set, and min/max lenght scales are 0 and 1000m?). for your udf-I got a bit rusty with fluent since I haven't used it in a while but...do you compile or interpret the udf and are you sure interpreted udf would be enough for the dynamic mesh udf? regards |
January 12, 2016, 12:09 |
regarding udf
#39 |
jessy dayal
Rep Power: 12 |
Hello komon,
i'm interpreting the udf, and it was giving the error which i told you earlier ....can you please give your mail id ..i think its better i send you the case file ... |
January 12, 2016, 12:42 |
#40 |
Rep Power: 15 |
Hi!
before this, try to compile the udf...look at this thread http://www.cfd-online.com/Forums/flu...f-problem.html |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 16:33 |
How to use UDF to define a moving wall | lingo | FLUENT | 9 | August 19, 2014 10:14 |
stationary wall vs. moving wall | user0314 | FLUENT | 0 | August 26, 2011 10:42 |
udf variable for wall temperature | Kiran | FLUENT | 0 | July 31, 2008 09:31 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
