Transition SST tuning using UDFs
Old   March 8, 2012, 12:45
Default Transition SST tuning using UDFs
robboflea is on a distinguished road
Dea all,
I'm doing some experiments with transition SST model and I would like to tune it using UDFs since it's not working really well for my case.
I read the fluent manual (https://www.sharcnet.ca/Software/Flu...udf/node53.htm) and I saw that it's possible to set values for Re_{Theta_t}, F_{length} and Re_{Theta_c}.
What is not clear to me is how those quantities are defined. Is for example F_{length} a length in meters? Is it a non dimensional vlaue? And if yes how it is non-dimensionalized? Same thing for the Reynolds numbers above. What are the quantities used in the definition of them according to Fluent?
The manual is not really helpful for this case because it says that Re_{Theta_t}, F_{length} and Re_{Theta_c} are proprietary correlations that are not shown for obvious reasons in the manual.
Help is really appreciated.
Thanks a lot
Rob
robboflea is offline   Reply With Quote
Old   May 16, 2013, 09:31
Heini Rasmussen
Heini is on a distinguished road
Hi Rob
I'm having simmilar issues as you had. Did you get answers to your questions? If so I would really like to get an explination about the UDF parameters.
Heini
Heini is offline   Reply With Quote
Old   May 16, 2013, 13:31
Hi Heini,
unfortunately I never had any reply to my message. I simply gave up with that approach.
Let me know please if you discover anything useful
Cheers,
Rob
Originally Posted by Heini View Post
Hi Rob
Heini
Transition SST - Intermittency/Tu Decay/Y+ Kloz FLUENT 4 November 19, 2018 01:54
SST Transition model in Fluent 12.0 Far FLUENT 1 November 8, 2010 02:32
Missing Information in SST Transition Model Formulation Josh CFX 2 September 14, 2010 12:49
to LANGTRY ROBIN :help, hypersonic transition SST ben akih CFX 0 September 21, 2006 05:59
flat plate transition: SST k-omega divergence Peter Gasparovic FLUENT 4 May 3, 2005 14:54
