UDF Parallel error (Is operating only in the serial.)
Old   March 7, 2012, 08:26
Default UDF Parallel error (Is operating only in the serial.)
Jong Hwan Park
startup0820 is on a distinguished road
Hello?
I want to ask you about the parallel issues udf.
Currently I am using the version of FLUENT 13, and the computer is windows 7 64bit.
When I compile the udf in serial no error occurred, but
In parallel, the following error occurs.
# Generating ud_io1.h
rotor_model_v8.0-p1.c
..\..\src\rotor_model_v8.0-p1.c(2811) : warning C4047: 'function' : 'float *' differs in levels of indirection from 'real [10][3]'
..\..\src\rotor_model_v8.0-p1.c(2811) : warning C4024: 'mphost_to_node_float' : different types for formal and actual parameter 1
..\..\src\rotor_model_v8.0-p1.c(2840) : warning C4047: 'function' : 'float *' differs in levels of indirection from 'real [10][20]'
..\..\src\rotor_model_v8.0-p1.c(2840) : warning C4024: 'mphost_to_node_float' : different types for formal and actual parameter 1
Generating Code...
d:\cfd_work\fluent\exercise\p1\libudf\src\rotor_mo del_v8.0-p1.c(3309) : warning C4716: 'xmom_src_1' : must return a value
d:\cfd_work\fluent\exercise\p1\libudf\src\rotor_mo del_v8.0-p1.c(3336) : warning C4716: 'ymom_src_1' : must return a value
(chdir "libudf")()
(chdir "win64\3d_node")()
If you're not too busy, I hope you would advise me..
Have a nice day!
startup0820 is offline   Reply With Quote
Dynamic Mesh- Parallel UDF DE HEART Fluent UDF and Scheme Programming 14 August 11, 2010 02:29
loading udf in parallel sytem tahere FLUENT 5 December 13, 2008 02:17
Help: Serial code to parallel but even slower Zonexo Main CFD Forum 4 May 14, 2008 11:26
UDF problem with Parallel Solver manu FLUENT 0 January 24, 2008 15:31
Help: how to realize UDF on parallel cluster? Haoyin FLUENT 1 August 6, 2007 14:53
