UDF resulting in negative volume..
Old   February 22, 2012, 15:13
Unhappy UDF resulting in negative volume..
djan is on a distinguished road
Hi, im using the following udf to bend a 3D beam as though having a parabolic loading in fluent. But it shows negative volume when i try to preview the mesh motion. I m using very small smoothing and remeshing numbers anyway. So I would be grateful if someone could point out my error. Thank you.
#include "udf.h"
DEFINE_GRID_MOTION(wing, domain, dt, time, dtime)
Thread *tf = DT_THREAD (dt);
face_t f;
Node *v;
real dispy;
real NV_VEC (position);
int n;
SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
begin_f_loop (f, tf)
f_node_loop (f, tf, n)
v=F_NODE (f, tf, n);
if (NODE_POS_NEED_UPDATE (v))
NODE_POS_UPDATED (v);
position[0]=NODE_X(v);
position[1]=NODE_Y(v);
position[2]=NODE_Z(v);
dispy=NODE_Z(v)*NODE_Z(v)*0.0271+0.2496*NODE_Z(v)+ 0.1396;// y displacement based on the present z position
NODE_Y(v)=+dispy; // new y position is equal to the present y position + displacement
end_f_loop (f, tf)
djan is offline   Reply With Quote
fluent, udf error
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Turbogrid and Negative volume Ali CFX 12 August 18, 2016 15:31
Negative volume in moving mesh mvee FLUENT 5 September 30, 2011 13:56
Negative Volume Elements windsim ANSYS Meshing & Geometry 3 September 21, 2011 01:26
volume flow rate error in udf jjchristophe Fluent UDF and Scheme Programming 1 July 13, 2010 05:23
