Calculate the entering flow rate in each cell |
February 21, 2012, 05:21 |
Rep Power: 16 |
Hi at all!
I am trying to find a way how to calculate the flow rate that enters or leaves a cell. In sum it should be zero but I like to find out a specific value for each cell of the domain. Does anyone has an idea how to approach this? Thank you very much in advance. |
February 21, 2012, 21:11 |
#2 | |
Rep Power: 17 |
May 30, 2012, 12:11 |
problem trying to get the mass flow entering a cell
javiercran
I have tried to calculate the mass flow entering inside a cell (for a DEFINE_SOURCE macro) with a loop over the faces of the cell but I have problems of "non-integer subscript expression: unsigned char". This is my code #include "udf.h" #include <mem.h> DEFINE_SOURCE(theta_momentum,c,t,dS,eqn) { //near peak operating point real Ft; //Ft source term real T01; //Inlet Total temperature real T02; //Outlet Total temperature real cp; //variable which will store the specific heat of air real x[ND_ND]; //array for storing the centroid position real pi=3.1416; real omega=16043*2*pi/60; real r; face_t f; real massflow=0; real volume; Thread *f_thread; int n; c_face_loop(c,t,n)//line 21 the one which gives problems {f=C_FACE(c,t,n); f_thread = C_FACE_THREAD(c,t,n); if(F_FLUX(f,f_thread)>0)// only calculate the massflow entering {massflow=massflow+F_FLUX(f,f_thread); } } massflow=massflow*2*pi;//axisymmetric volume=C_VOLUME(c,t); T01=288.15; cp=1006; C_CENTROID(x,c,t);//we store in x the centroid position of each cell r=x[1];// the radial position is the y-coordinate of the cell centroid r = x[1]; T02=1.164*T01; Ft=massflow*cp*(T02-T01)/(volume*omega*r); dS[eqn]=0; return Ft; } I need your help because I cant see the mistake I am doing. Regards |
Mass flow rate: calculation v/s computation | beguxa | FLUENT | 5 | December 2, 2018 22:02 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 01:32 |
How to calculate the mass flow rate with UDF ? | HP | FLUENT | 0 | January 10, 2005 20:38 |
sos! How to define the flow rate of outflow BC? | zjm | FLUENT | 0 | June 4, 2004 10:12 |
cell flow rate | sivakumar | FLUENT | 0 | March 31, 2003 15:05 |
