Can I get x,y,z coordinates of a particle in lagrangian simulation
Like Tree1Likes
Old   January 30, 2012, 14:16
Default Can I get x,y,z coordinates of a particle in lagrangian simulation
mali28 is on a distinguished road
Can I get x, y, z coordinates of particles moving in a fluid. The particles are tracked using lagrangian approach.
Thank you.
mali28 is offline   Reply With Quote
Old   January 30, 2012, 15:11
Amir's Avatar
Amir
Amir is on a distinguished road
try this:
report-> discrete phase-> sample
select default-interior in boundaries panel and desired injections from injection pane then open the created file with a text editor which has "dpm" extension.
Bests,
Amir
Amir is offline   Reply With Quote
Old   January 30, 2012, 15:51
Originally Posted by Amir View Post
try this:
Bests,
Thanks, but I need it inside UDF because I want to apply modified drag coefficient due to close packing of the particles. For that I will need to know at any instant what the coordinates of a particles are and its nearby particles. If the distance between two adjacent particles is less than twice of diameter then modified drag coeff. will hold, other wise the one used by Fluent will be applied.
Any thoughts?
Old   January 31, 2012, 04:28
Amir's Avatar
Amir
Any thoughts?
Ok, your goal needs few settings; first of all, you can use P_POS(p) in a UDF in order to access the particle coordinates, but I think that because of using less memory each particle ise solved from the start to the end of its trajectory and then switches to another particle (check it); so if you want to have particle interactions you have to use a journal file in this manner:
  • compute the all of particle trajectories for one (and equal) time step. (you may want to write additional UDf to adjust the time step)
  • correct drag coefficients and other modifications
  • compute for the next time step
Bests,
Amir
Old   January 31, 2012, 04:47
laurentb's Avatar
Laurent B
laurentb is on a distinguished road
This is an udf example which save in a file particle data (id, position, velocity and velocity derivatives). It may be useful :
# include "udf.h"
FILE *fp;
DEFINE_ON_DEMAND(open_file)
fp=fopen("data.txt","a");
DEFINE_DPM_SCALAR_UPDATE(trajectory,cell,thread,in itialize,p)
// COMPILED MODE ONLY
fprintf(fp,"%d %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g %10.6g \n",p->part_id,p->state.pos[0],p->state.pos[1],p->state.pos[2],p->state.V[0],p->state.V[1],p->state.V[2],p->state.time,C_DUDX(cell, thread), C_DUDY(cell, thread), C_DUDZ(cell, thread), C_DVDX(cell, thread), C_DVDY(cell, thread), C_DVDZ(cell, thread), C_DWDX(cell, thread), C_DWDY(cell, thread), C_DWDZ(cell, thread));
DEFINE_ON_DEMAND(close_file)
fclose(fp);
laurentb is offline   Reply With Quote
Old   April 5, 2012, 19:00
Default Modifying Cd by particle spacing
John
Mr. CFD is on a distinguished road
@mali28
Any thoughts?
Hi mali28, I am currently trying to do the same thing. What exactly are/were you simulating? Since it looks like you solved your problem, would you be kind enough to tell me just how you did it?
Thanks!
Mr. CFD is offline   Reply With Quote
Lagrangian particle tracking skabilan OpenFOAM Running, Solving & CFD 7 July 15, 2014 13:40
Euler-Euler vs. Lagrangian particle tracking for biomass pyrolysis in a rotary kiln audrey Main CFD Forum 0 February 22, 2011 13:09
Pressure gradient in particle simulation Mikka Main CFD Forum 0 August 5, 2007 22:55
Pressure gradient in particle simulation Mikka Main CFD Forum 0 June 30, 2007 23:16
air particle simulation software kong Main CFD Forum 0 February 11, 2006 23:33
