Probleme to interpret 3D temperature profil UDF |
January 16, 2012, 10:23 |
christophe REHMET
Rep Power: 14 |
I have defined a UDF for 3D Inlet temperature profil and it doesn't works anymore after a crash of fluent. My profil has become flat and I couldn't have good interpretation of all my UDF know. It's really a bad point because I need to give a report about these CFD results this week. I have writing the temperature profil as followed: #include "udf.h" "define domain_ID 2 // enum{OC, NUM_OF_USED_UDM}; DEFINE_PROFILE(inlet_temp, t, i) { real x[ND_ND]; real r; face_t f; real Diameter = 6.e-2; real T_max = 5.e3; real T_max = 3.e2; begin_f_loop(f, t) { F_CENTROID(x,f,t); y = x[1]; z = x[2]; r = sqrt(pow(y,2)+pow(z,2)); F_PROFILE(f, t, i) = (T_max-T_paroi)*(1-pow(2.0*r/Diameter,2))+T_paroi; } end_f_loop(f, thread) } |
January 16, 2012, 11:58 |
christophe REHMET
Rep Power: 14 |
I find the solution, I just restarted from the beginning,it was fun
February 19, 2012, 16:08 |
Adapt UDF
PB
Rep Power: 14 |
Hi there,
I want to do the exact same UDF as you but my inlet is rectangular shaped and I was wondering if you could explain how to adapt your code to fit non-cylindrical coordinates? I am trying to model a hot spot temperature on the inlet of a gas turbine duct. Your help would be much appreciated. Kind Regards AeroGirl |
February 20, 2012, 05:49 |
christophe REHMET
Rep Power: 14 |
I think that you can define your profil along one direction, for example X and add other condition on Y. #include "udf.h" "define domain_ID 2 // enum{OC, NUM_OF_USED_UDM}; DEFINE_PROFILE(inlet_x_temperature, thread, position) { real x[ND_ND]; real r; face_t f; real lenght = 6.e-2; real T_max = 5.e3; real T_max = 3.e2; begin_f_loop(f, t) { F_CENTROID(x,f,t); x = x[0]; F_PROFILE(f, t, i) = (T_max-T_paroi)*(1-pow(2.0*x/Diameter,2))+T_paroi; } end_f_loop(f, thread) } DEFINE_PROFILE(inlet_y_temperature, thread, position) { real x[ND_ND]; real r; face_t f; real lenght2 = 2.e-2; real T_max = 5.e3; real T_max = 3.e2; begin_f_loop(f, t) { F_CENTROID(y,f,t); y = x[1]; F_PROFILE(f, t, i) = (T_max-T_paroi)*(1-pow(2.0*y/Diameter,2))+T_paroi; } end_f_loop(f, thread) }Maybe this script will be ok. |
February 20, 2012, 09:06 |
Thanks!
PB
Rep Power: 14 |
Thankyou I will give this a try and see how I get on!
UDF: temperature profile | dolores | FLUENT | 6 | August 5, 2016 21:16 |
Please Help! Temperature profile UDF for 3D geometry | subhankar_bhandari | FLUENT | 2 | April 16, 2011 06:30 |
Please Help! Temperature profile UDF for 3D geometry | subhankar_bhandari | FLUENT | 0 | August 16, 2010 09:40 |
UDF or any approach for Bulk Temperature calculation | vemps | FLUENT | 0 | May 1, 2009 02:09 |
Interpret three UDF for property | Atsu | FLUENT | 4 | April 22, 2006 16:04 |
